Question about Refrigerators
Model number 52602100 need to order seals for freezer and fridge
Need to order seals for fridge and freezer.
    Top Expert:
  • Refrigerators Master
  • 22,188 Answers
Ok sooo contact the makers
Posted on Feb 21, 2019
57 varieties
  • 1653 Answers
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Posted on Aug 29, 2009
  • 1218 Answers
SOURCE: I need wiring diagram for our General electric Fridge Freezer
I don't like the idea of someone just recharging a system without knowing what's truely wrong.
At this point, based on what you've said, I strongly recommend you call G.E. factory service or a dealer with a qualified service tech in the G.E. line.
G.E. has made the use of a lot of solid state boards, which may well be some if not all of your problems. It will be pricey, but a refrigerator is not a toy. I would advise the tech as well, that you had a recharge performed, and let him follow up on it.
Sounds like whoever worked on your machine isn't well qualified to service it. Newer G.E.'s can be a real bear. Sorry....
Posted on Oct 20, 2009
  • 66 Answers
SOURCE: my brother has a AEG fridge freezer he thinks the
The R600a is the isobutane gas in the system. The 412 is probably the alternate gas to be used. The KG2 is probably the weight. You have the make & model number above. most magnetic door seals will fit you buy it in a roll and cut it to size.
Posted on Apr 18, 2010
  • 523 Answers
SOURCE: Westinghouse Fridge Freezer Frost Free but is frosting up
change the timer
Posted on May 05, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: door seal between fridge & freezer is hot is this normal ?
No, there is a heater in the seal of the doors to keep the doors from icing up, if it is hot to the touch then the heaters are going bad and must be replaced. You can replace it yourself by removing the door seals, and then removing the heating element that runs the whole door. When you do this make sure that the unit is unplugged.
Posted on May 17, 2010
Hi, I think the seal is damaged on my fridge freezer. It is a CB18m/1c/fan whirlpool fridge freezer. Where do i look for a replacement seal? Thank you
Is a package/or a shelf blocking the door? If a gasket is required & damaged it would be noticeably different than the look of the rest of the gasket. The door originally was held straight by the screws behind the gasket & a undamaged door liner(cracked with weight of packages will cause it to twist), if it is twisted than it can be realigned by twisting it straight & may have to loosen the screws a little first & then snug them back up after it has been twisted straight. Gaskets generally have a flat magnet in them to pull the door up to the body of the fridge & with a model number(or take the gasket to them is the worse scenario) can be obtained from a Major appliance store or they can order it.
Dec 12, 2013 | Refrigerators
Fridge not cooling
Check to see if your evap in the rear of the freezer is icing up. I had the same concern a month ago. My evap fan( one in the freezer) went out and ice formed in the freezer becuuase of no air flow. The fan you hear running in the freezer also supplies flow to the firdge section through a "dma\\ampner" If your freezer is cold but fridge section is not I would check for a blocked section(blocked with ice build up) where the flow of cold air to fridge section is restricted. I would use your model number and go to www.appliancepartspros.com and search for your fridge with your model number. This will give you a parts, mounting and routints breka down of your fridge and you will have a better idea what your dealing with.
Sep 24, 2012 | Jenn-Air Refrigerators
I am wanting to replace the freezer door seal on a upright fridge freezer model BJ 423TR*16
contact this company here http://www.allbrandonline.com/ you will be able to order your door seals from this company and they will mail them to you 1800-252-7500 is there number also remember after you install the seals to coat the seals with petroleum jelly or vaseline and leave the door of the freezer closed for at least 3 hours this causes the door seal to mold properly and keep the proper suction to make sure the door stays snug and grabs onto the frame if you have any questions message me back and please remember to rank how this opinion has helped it allows me to continue helping people in similar situations in the future on this site Thanks again Rick
Apr 30, 2011 | Westinghouse Electric Refrigerators
My brother has a AEG fridge freezer he thinks the part number is either R600A or 412 or KG2 we need new door seals for both doors can you advise the part numbers needed? it is a fridge at the top and a...
Apr 17, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
What is the cost and where to buy rubber seal for Bos
Need the model number to find the related costs.
Try this website link; just enter the model number and you can get the spares you need and order them.good luck.
click here and enter the model number
Apr 11, 2009 | Refrigerators
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridge Freezer door replacement
You will need to order part number 059129. It will be in Europe/Germany phone +43-140447-200 for customer svc, +43-140447-300 for parts. Don't know if there is a US distribution office.
Feb 15, 2008 | Freezers
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
