Question about The Watches
How can I change the battery of the Danbury quartz?
  • The Master
  • 25,703 Answers
I have a Movado Series 800 Subsea. It stops running when it's not worn. If I shake it, it starts up agin. I know it's a quartz hence a battery. Is it kenetic? The manual does not say.
It is not kinetic, the watch should run whether it is worn or not. A kinetic watch requires motion in order to wind a mechanical movement. A quartz movement requires a battery and that is all. You might want to change the battery.
Feb 17, 2014 | Watches
How to you change the battery in a danbury book clock
The clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes free. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jul 30, 2013 | Watches
Changed battery, now buttons on sides do not work, where to get it repaired?
mcdevito75 here, Most likely during the battery change you moved the quartz movement away from the contact buttons. Re-Open your watch carefully and make sure when you press the buttons, each button is pressing against it"s spot on the quartz movement.
Jun 17, 2011 | Mio Motiva Petite Heart Rate Monitor Watch
Hi, I found on a street market a MIYOTA T241 watch in original package, also a plastic shield on the glass. Now the problem: May be the liquid of the battery destroyed any power supply wires or contacts. I...
mcdevito75 here, Once the battery leaks it destroys the quartz mechanism. Even if you find a replacement quartz, you"d need special Jewelers tools to remove and replace the quartz, even with that you could destroy the new quartz if you can find one. Best Bet, see a small watch repair shop in your area for a quartz replacement approx. $75.00
Sep 29, 2010 | Watches
I just replaced the battery on a fossil watch and it won't work. How to you reset it? or what else needs to be done? Please help me. thanks.
mcdevito75 here, Your Fossil watch should work with the battery change, of course it will need to be re-set. You"ll have to double check the battery install, make sure the battery contacts are clean, use a piece of paper towel and carefully clean the battery contacts. Hopefully your new battery is not dead. Another thing to check for, is that the buttons contacts are lined up with the quartz movement. While you double check your battery install, carefully press 1 button at a time, and make sure each button is making contact with the quartz mechanism, many times during a battery change to quartz movement may move just slightly but enough to keep the buttons from contacting the movement, this will keep the watch from working. Hopefully 1 or all of these is the answer for your Fossil watch.
Aug 22, 2010 | Watches
My watch ar2434 is not functioning properly. the seconds hand moves for some time and then stops. i changed the battery but the problem still persists. what could be the problem?
mcdevito75 here, The quatrz movement could need a little quartz oil or the quartz movement could be going bad, but foirst check make sure you have the correct battery and that it didn:"t work loose Return to whoever changed the battery to have it checked.
Jul 21, 2010 | Watches
New battery want work? I tried two new ones and nothing worked? Need help.
mcdevito75 here, You may need to start your watch by pressing the MODE button. Most quartz watches will stop once you"ve changed the battery, of course the possibility is there that the watch quartz has burnt out also. See a small watch repair shop in your area.
Jun 30, 2010 | Fossil BQ9177 Wrist Watch
New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
Jan 24, 2010 | Timex 27191 Wristwatch
How do I change the quartz battery on a Longines La Grande Class
Just unscrew the screw at the back if your model have screw if not the other one snap to open.Use a pocket knife then open it look the number battery and replaced it with same number battery. Its you use Renata battery it is swiss 3years to last.
Hope it may helps;
Regards;
VOTIT
Jun 16, 2009 | Longines La Grande Classique L4.709.2.42.9...
Watches Logo
26 people viewed this question
Top The Watches Experts
vince
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
