Question about The Computers & Internet
I have a sirclelam la-330. the ready light is blinking green. it normally is a solid green. what does the blinking mean?
    Top Expert:
  • The Master
  • 50,997 Answers
The blinking may indicate that it isn't ready.
Posted on Feb 21, 2019
Testimonial: "What if it stays blinking and never goes solid? It used to be solid."
SOURCE: Ready/Error Light
IT have just been down to look at our scanner & cleaned the sensor which is in between the rollers just where the paper flits out at the bottom - we now have a green light! So look for that sensor.
Posted on Jan 29, 2008
printech
  • 159 Answers
SOURCE: brother hl-2070n
The printer is ready to print. Pressing control panel button wakes up the printer to Ready mode
Posted on Apr 08, 2008
22yooper
  • 828 Answers
SOURCE: green light on the front
Your problem is more than likely in the light itself. The green light is the indicator that the temperature is in acceptable range.
Posted on May 16, 2008
  • 81 Answers
SOURCE: blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Posted on Jun 16, 2009
  • 81 Answers
SOURCE: The printer has a solid green ready light, a solid
Try removing the jetdirect and power cycle the printer.
Posted on Oct 12, 2009
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
I need the manaul for this product. I do not know what the the flashing light mean, and I was given this product from another co-worker....but no one knows what the lights mean?
Hello, you can download the manual here: http://www.plantronics.com/us/media/media-resources/literature/user_guides/73156-01_CS55_US_DL.pdf?WT.dl=20 It says that a flashing amber light means charging, a solid amber light means charged, a solid red light means power, a solid green light means talking, and a blinking green light means muted.
May 16, 2011 | Plantronics CS55 Wireless Headset
The ready light is flashing green then amber. What does this mean
This lights pattern means the waste tank needs the blotter replaced.
Then once replaced, the tank reset needs to be performed.
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and release the Resume button
4. Press Resume button 2 times then release BOTH buttons.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Jun 15, 2010 | Canon i950 InkJet Photo Printer
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
Power light flashs off and on and pc clicks
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard.
A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Well, I was sure that the voltage selection switch was in the right place. And I found it highly unlikely that the processor power cable would suddenly unseat itself. Ugh.
Then I had an idea. I flipped off the surge protector and then flipped it back on. Tada! No more orange lights. Weird. The moral of the story: try the simple stuff first.
I hope this helps and please dont forget to rate my answer. Thank you! :D
Apr 28, 2010 | Dell OptiPlex SX280 PC Desktop
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Ethernet light is green but continuously blinks is there a problem with modem or ethernet cable?
no, a green light means there is a connection with the network and dns server (gateway to the internet) information is sent allow this network in bundles called packets. Each time a packet is sent the green light blinks.....sometimes when many packets are being sent in succession the light will appear solid. so i wouldnt worry, the green lights on your router and computer are normal and you should become concerned if these lights turn yellow or stop blinking completely.
Good Luck and Please Rate This Post!!!! :D
Oct 14, 2009 | 2wire (1000-000057-000) Modem
No black ink
Canon S330 Turn off printer
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
Your printer should respond as normal
Nov 22, 2008 | Canon S 330 InkJet Printer
Printer will not respond
Jul 22, 2008 | Canon S 330 InkJet Printer
Computers & Internet Logo
23 people viewed this question
Top The Computers & Internet Experts
Inky Fingers
Inky Fingers
Fred Sops
Jorge Smith
Jorge Smith
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
