SOURCE: IBM Wheelwriter 5--Carriage advance problem
Try code (lang) key either the X or L depending on when it was made
DickyO
SOURCE: IBm Wheelwriter 5--6 keys won't advance after typing
Press and hold the code key while pressing the lang key Either "X" of "L" key.
DickyO
SOURCE: IBM Wheelwriter 6 ribbon not advancing
Befor you put a nrw motor in try a few drops of light oil on the m
motor bearings (WD40 works well).
DickyO
SOURCE: IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
I have made a copy of the IBM Wheelwriter manual for you. If you send me an email to LBrown18062@hotmail please be sure to put IBM Wheelwriter as the subject and I will send it to you right away. Lawrence Brown
