SOURCE: Need to Buy a main system board/controler board for BenQ DV3750
Really Did not find a solution because we already know the problem. i.e the mani/digital board. BenQ will not sell us the part. We are still looking for a supplier.
NEVER NEVER Buy BenQ
SOURCE: Carrier gas pack inducer motor
Sounds like you may have a bad connecton at the end, which end? if you follow the wires out of the motor they sometimes go to a MOLEX whitish plug. The wires treminate in this plug with PINS sometimes these PINS dont seat or come loose in the plug. Pull the plug apart and check the wires comming in from both directions. If they wont push or pull out of the plug either way they are seated ok. Check for a bent PIN while have it apart. If its worse and this dosnt fix it or its the end going to the motor consult www.carrier.com for a dealer near you. DO NOT USE A GENERIC MOTOR on your furncae as I believe it is a 2 speed and most generic motors ar only 1 speed. SOme of these gaspack motors have a centrifical switch and if this is your problem again consult with a carrier dealer. The price of the motor is secondary to safety and longvity of your comfort investment. If I knew where you lived I could make a better recomendation.
A viberation could mean a HORNET nest (using mud for their nest) could have been in place and reciently came loose and fell into the fan on the motor. carefully remove the assembly and inspect it for bent fan or shaft or maybe plastic and broken or metal rusted out parts.
If you need more information I need to know a few more things. If this helps you r not please grade accordingly and help me improve. THANKS AND GOOD LUCK.
SOURCE: My Kenmore electric dryer runs but no heat ....
Hi, You will need to remove the front lower panel and this will get you to the element and thermostats.
With the dryer running. check voltage to the element and you should get 240V. If there is voltage, you will need to change the element.
If there is no voltage to the element, UNPLUG the dryer and check the thermostats and fuse for continuity. These parts are located on the element housing and the blower housing under the drum.
If any of the thermostats or the fuse are open, they will need replaced.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
SOURCE: need to repair model 20605 washer, motor does not
Welcome to FixYa.
Sorry to hear about your trouble shooting problems. I hope I can help move you forward in the right direction.
Have you run a self-diagnostic which is built into the Asko washer's control ? Furthermore, Did you initially receive an error code of "F6" ?
What led to the changing of the brushes in the motor, and was the motor windings ohm value checked to confirm or dismiss the motor was worth brushes ? The armature inspected ?
This how to run a fault tracing program ( in the event you don't know )
What you will/should see...
Let me know what you've done or found to this point and I'll try to help in whatever manner I can. It is possible the motor control board is the fault, but there is a means to get to that point first.
There was also a period of time during production some of the controls had the wrong fuse placed in them...se below for memo.
This is not very likely considering the age of your machine, however I felt it was worth mentioning. I'll watch for your next post.
Regards,
Macmarkus :)
SOURCE: I NEED USERS GUIDE OR
I have the operators manual for the SM-25, but not a programmers manual
