I have not seen anywhere that knows the answer to this... not in the manual.. I have ripped it all apart and seen not one oil adjustment screw.. hope you find a way but I think it's full auto
Should be able to. Check your manual
http://www.manualsonline.com/
SOURCE: how to adjust chain and bar oiler flow
The chain should be adjusted so that the chain can be pulled by hand fairly easily, but doesn't droop from the bar underneath. Oil flow should be set so that a running engine (chain moving fairly fast) will send a thin line of oil off of the tip of the bar (onto a piece of cardboard) with a few moments of running. Hope this helps!
Testimonial: "Thanks for advice about oil flow !adjustment needed I think !!"
