I have a Craftsman weed trimmer with the speed start it starts up just fine but when I give it gas it dies on me and its not the 2-n-1 mixture cause I know this is right and when its in the on position it starts right up and stays idle but as soon as I give it gas it bogs down and then kills it and I have already tried the adjustments and know change any takers on this one.. Thanks in advance..
SOLVED: Craftsman 25cc Gas Line Trimmer dies when giving - Fixya
www.fixya.com/support/t5186018-craftsman_25cc_gas_line_trimmer_dies
1 answer
Nov 11, 2017 - Drain the old fuel and make sure the fuel filter is attached to the fuel hose ... SeaFoam or a product called Start will sometimes clean the ... Craftsman gas 25cc weedwacker starts, runs a few secs, then dies. The gas take up line is disconnected or is broken. ... You should be fine for next season that way.
I have a Troybilt TB10CS trimmer that starts and ...
Oct 20, 2012
Craftsman 29cc dies when depressing throttle
Aug 27, 2012
SOLVED: My craftsman p2 weed eater won't stay ...
Aug 6, 2012
SOLVED: Weed eater bogs down when i try to give ...
Sep 15, 2010
More results from www.fixya.com
SOURCE: I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
Hope this helps!
SOURCE: weed eater bogs down
Under what conditions does it bog down? When it just idles? Cold or hot? When you give it gas? When you try to cut?
SOURCE: How to remove the carburator from the Ryobi SS30
It may just need a G & D kit installed. That is a gasket and diaghragm. Just take the 4 Torx screws out of the rear cover and remove it. You will then be looking at the choke plate assembly which has 2 long screws that go through the housing of the carb and screw into the rear crankcase cover/reed valve assembly. Pull the 2 fuel lines off (noting where they went) and you'll have it. Once you have the carb off, you can get the manufacturer and model # off of it and order a kit. The G&D kit will probably fix what ails it or you can go for a complete rebuild and get a rebuild kit. If the carb is a Zama or Walbro, they sell the kits on Ebay.If the carb has brittle diaghrams inside, replace them; if they are still soft and pliable, then you may only need to clean the carb real well and adjust the H and L mixture screws. They will be plainly marked, but are difficult to remove. Post back for more help!
SOURCE: my craftsman p2 weed eater won't stay running
remove the muffler and run it if ok open the muffler and cllean the screen inside a resticted exhaust will not allow exhaust flow then the engine can't rev up
