Laminator was running, pressed stop button in the back to stop, got a shock and it would not stop. unplugged it and now it won't run
SOURCE: GBC Eagle 35 Laminator heats up, won't turn
if you cannot get this fixed....i will buy it for spare parts.....408-802-3843
regards Cliff
SOURCE: My ultima 65 laminator is not sealing well on the
By "upper tension" do you mean the hex screw located inside the left panel? If you tighten this until there is no space between the heat rollers it should eleminate the problem. If it is continues to loosen, back the screw out, apply a small amount of locktight to the threads before replacing the screw.You can find locktight at any hardware store usually in the Paint section near the glues. Hope this helps. Good luck
SOURCE: I have a zebra p520i
This sounds like the feed rollers need cleaning. You can use the correct cleaning cards (your dealer should be able to get them for you - but make sure you follow the instructions on the card carefully) or use IPA fluid.on a lint free cloth.
SOURCE: Was driving 65 miles an
check for spark at the spark plugs. If ok then check for fuel and if that's ok then you need to check the timing chain.
SOURCE: Aeq6700fso dryer dryness button won't change the
E68 is a stuck button on th control panel
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
