Get free help, advice & support from top Xerox experts. ... sensor. but I don't know how and the manual tell me to set nvm-776-374 and nvm-776-062 to zero.
Missing: grid cronton 5865
Its crucial to make people feel comfort close us. We are need different people for the duration of our life. We can't live alone in this life. That is the reason we need to make a fair association with all the all inclusive community around us.pass4sure-810-403
The error means that the interval of the ROS (C) signals exceeds the specified value. The normal problem is a bad mcu board. Measure the value between PJ401 on the MCU board and and ground for +5vdc. If you get +5 then replace the MCU board. Part number 960k31352. http://www.iteminconline.com/itemdesc.asp?ic=960K31355&eq=&Tp=
The interval of the ROS SOS (Y) signals exceeds the specified value.
Procedure
+5VDC is measured between the MCU PWB P/J401-B20 (+) and ground (-)
Y N
Replace the MCU PWB (PL 13.1).
Check the wire between the SOS PWB (Y) P/J516-1 and the MCU PWB P/J401 for an open
circuit.
Check the wire between the LD Drive (Y) J529 and the MCU PWB P/J401 for an open circuit.
If no problems are found, replace the ROS Assembly (PL 3.1).
If the problem continues, replace the MCU PWB (PL 13.1).
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . [email protected]
sir
u do one thing press 0+ start & go to max setup
trc adjustment press start u can get a3 print
next trc toner concentration start
ofter u can get some defference
The ROS is the laser. Believe me you can replace the machine for less than the cost of a laser. The Polygon motor is most likely bad in the laser. I would guess in the $500 range for the laser
