Once the document is loaded into the printer, you can enter the destination faxnumber on the printer's number pad. ... The printer will scan the page or pages and then send the fax to the number entered. You can find additional helpful videos at hp.Jun 13, 2013
Check for phone line connection issues that might be causing failed sent faxes. Call the fax number you are sending to from a phone: If you do not hear fax tones, the receiving fax machine might be turned off or disconnected. ... Connect the phone line to the 1-Line port, and connect the answering machine to 2-Ext.
SOURCE: Sending Faxes
This could be a cable fault. Get BT to do a line test for you (this is free). If that is OK, change the telephone cable. Perhaps this is on an extention cable? Remove it.
SOURCE: Fax does not receive or send
plz contact brother hotline of your country ( www.brother.com )because there are so many diffrent telephone standards which might affect a good working of the fax abillity.
SOURCE: We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
SOURCE: I can't get my new Canon Pixma MX330 to send
Better check the connection at the back of your printer. This is the most common problem encounter when faxing...wrong connection.
1. when using the printer as fax, the line input should be connected properly to the "L" input at the back of the printer
2. The rj11 connector of the phone should be connected at the back of the printer with telephone label in it
I hope that helps.
