SOURCE: Dishwasher
Gendos is on track with his question. I have the same dishwasher and it doesn't get enough hot water to clean the dishes and runs for hours because the heating element wasn't designed to heat water, just maintain it. The only solution we have found is to run the hot water from the kitchen faucet before we start the dishwasher. The only long term solution is to install a circulation pump on your hot water line, or find a dishwasher that pre-heats the water.
SOURCE: hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
SOURCE: bosch dishwasher is it hot or cold water supply
All dishwashers use hot water supply.
Testimonial: "rapid and helpful response to my question many thanks"
SOURCE: Dishwasher
This "Inductive heating element"is in line with the pipe feeding the top spray arm. it is about 15cm long and has a clamp at each end with one electrical push on connecter. It can be reached by taking off the back bottom plate and just follow the spayarm down to this device.
Always supply hot water to the dishwasher...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Check
A
Dishwasher
Element not Working
How
Dishwasher
Maintenance
heatman101
ronnieshomes
