Apple 13 MacBook Notebook Computer  Z0H1-0002 Mac Notebook Logo
Posted on Aug 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MacBook Notebook will not connect to network via Zyxel Prestige router. Asks for WEP password and then says unable to join the AirPort network. If I change the Mac Filter in the router the other computers on the network lose their connection but the Mac still will not connect.
  • macleans Aug 05, 2009
    Already checked that 5 times! Most frustrating
Anonymous
Level 3:
  • Master 1,768 Answers
  • Posted on Aug 05, 2009
Anonymous
Master
Level 3:
Answers
1768
Questions
0
Helped
528240
Points
5915
Check you password in a word pad before typing it in to see if you have caps lock on /type WEP password in word pad then copy and paste in to field and see if you can log on
2answers
I have tried "admin" and "password" to get in to get my WEP key to add my sons netbook to our router, but it is not working. Can I reset the original login and password?
if you feel you are apart distance than other peoples wifi connections and safe,, then you can diable pass word in settings,,and log to your sons notebook..
2answers
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
did you setup a wireless network ? if you didnt go to control panal and then wireless network setup icon and follow instructions (select automatically provide network key option) then follow instructions and finish. once you did that, search through wifi on youf phone it should find your WNetwork and then connect and enjoy. if you want to use internet and have an ADSL modem, make sure that the modem is connected to the internet RJ45 plug on your router. and from router to PC.
good luck, i hope this helps
i had the same problem too with my'n. My issue was on of my setting's was set to block that wi-fi connection. Try switching your setting for finding internet connection from automatic to manual. that should do the trick!
16helpful
6answers
Can't connect my router to my Ipod touch?
ok do this if it is already showing your router up on your portable device but it has that security lock and you are unable to join or need a password which u dont know lol go to that network and on the top push forget this network. than go back and click on for other location. than for the name put in your router name usually 5 characters long make sure u use capitalization cuz its case sensitive. than select what kind of key u have it should say right on the side of your wireless router. than type the key in usually a wep key and u should be set to join it if it doesnt auto matically do soo
9helpful
4answers
MacBook not connecting to DIR-655 Router
My solution was that I changed the wireless mode from "B,G and N" to just "B and G," and then it worked fine.
1helpful
Problem connecting to Router with Mac Airport
The $ sign or a hash character before the network key only works with WEP 64 bits on Mac, if you enabled WPA(is it TKIP or AES?) make sure that your Mac computer supports that kind of authentication if not try to lower down the security level on the router by using WEP instead of WPA.
Macbook pro network connection
Verizon, the ones who sent me the router, helped me fix the problem. The router/modem software has to be updated because the old software can't work with the new version of leopard. The technical support guy did all of the updating via a screen share, so your best bet is to call the company who sent you the router and get their help.
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
