Question about GE Computers & Internet
GE JVM1790SK01 Microwave Over the Counter Touchpad stopped working.
Tried the ribbon re-insert, didn't work. Tried the door wiggle, it worked. The turned it off. When I tried to test the vent fan, it won't work again, even after I did another door wiggle. Any advice?
    Habit-Forming:
    New Friend:
  • 93 Answers
If this is a standard plug & recepticle check that terminals on the recepticle are tightend down firmly, if it is hard wired from a junction box check wire nuts behind cover.
Posted on Feb 22, 2019
MicrowaveSvc
  • 9156 Answers
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 02, 2007
  • 92 Answers
SOURCE: GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Posted on Sep 11, 2009
SOURCE: Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Posted on Mar 27, 2010
MicrowaveSvc
  • 9156 Answers
SOURCE: microwave ge spacesaver touchpad does not work except for the
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
Testimonial: "Thank you for your detailed response. Nice to know you are there for support."
heatman101
  • 43501 Answers
SOURCE: I have a GE microwave # JVM2070SK02 that the
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 22, 2010
Ge profile microwave oven touchpad not working
The touch pad is more than like the problem. This is common. Try removing the ribbon connector and reinserting it back in the receptacle. If this doesn't fix the problem then replace the touch pad.
Oct 06, 2014 | GE Profile Spacemaker Over-the-Range...
I suddenly started having problems with some of the numbers on my touchpad not working on my microwave and wonder if there is a way that I can fix the problem?
If the touch pad is separate from the actual control board, you could just be looking at a bad connection between the two. If there's a ribbon cable from one to the other, it may attach to the circuit board via a connector on the circuit board. If so, you could try removing the cable from the connector, and re-inserting it. If there's no ribbon cable between the two, it is probably an electronics failure, and the entire circuit board/touch assembly would have to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 05, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
My GE profile Convention Microwave model JVM1790SK01 dial is loose and does not work. How can this be fixed?
see the information and use the common sense: God bless you
. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Sep 07, 2012 | Microwave Ovens
Ge microwave HVM1540DN1BB button control pad stopped working
I am not familiar with the Whirlpool microwaves; however, I just had the same problem with an LG over the range microwave. Several of the positions on the touchpad quit responding to touch. In our case, it was the touchpad itself that was the problem.
The touchpad on our microwave was held in place with adhesive. We pulled it off and replaced it with a new touchpad. Everything works now. The only complication is getting to the connector which carries the signals from the touchpad to the microwave controls. We had to remove and dissassemble the door to get to that connector.
The touchpad cost about $26.00.
Oct 09, 2009 | Whirlpool MH7140XF Microwave Oven
GE Spacesaver Microwave Oven JVM1640BB
unplug the unit and if you can open the housing and slowly remove the ribbon cable of the touchpad console to the main board. put it back after 5 minutes and try it. let me know what happen.
Feb 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I don't hear the fan, the carousel doesn't spin, nothing works but touchpad & light
It sounds like you may have an intermittent door switch or loose door switch mount.
Does it work differently when you wiggle the door?
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 19, 2007 | Sharp R-408HS Microwave Oven
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
My microwave has stopped working and switched on suddenly!!
Sounds just like a bad door switch or door switch mount. Probably the upper one. Safety info, disassembly tips, and door switch test and replacement info are all available at our Web site. See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM1660 Microwave Oven
Computers & Internet Logo
23 people viewed this question
Top GE Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
