When the machine is powered up, display is working but just says PRESS ESC + OK. Pressing either button beeps, but pressing the second on - nothing. Machine is locked. Background All was OK till I operated the machine during a brown out low supply voltage. On switching it on, the motor ran, but clearly not a full power - it was much quieter than normal, then hit this error. Full power back, same error. I have taken all the covers off, and the infuser was in it's upper postion. I was hoping it was just jammed so turned the motor by hand to get the infuser down and out, but no change. It looks like the logic is still working, as if the tank or grounds container are out, it displays the correct message like Insert Tank etc. Nothing on Google for this message. Completely stuck. Help please!
SOURCE: How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
SOURCE: Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
SOURCE: When I press the power button LG displaying chars for 1 second
Had the same problem, turned out it was due to a faulty capacitor on the inverter board, 680uF 25V (105 celsius rated). Simple to fix once you have the unit dismantled and the correct replacement part. Two screws hold the shroud on, but you need to be careful with an (old) credit card levering it off.
Unit is now working fine.
SOURCE: samsung sw51asp top loader washing machine
I had the same problem and from bit of research dE probably means door error. It turns out to be the reed (magnetic) switch was not functioning properly so wasn't closing the circuit when the door is closed.
DO NOT DO THIS UNLESS YOU HAVE BASIC UNDERSTAND OF ELECTRICITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Of you may really harm yourself.
To test if your problem is the reed switch then
1. Turn AC power OFF, unplug from wall
2. HAVE YOU TURNED THE POWER OFF?
3. Unscrew two visible screws on the back of the machine near the top
4. Take back lid off by pull up which will expose all the wires at the back
5. Put your head in the drum and look to the right under the edge you will see two wires (may be blue) connecting to a small rectangular grey unit (reed sw)
6. Follow the wires back to the back where all the wires are you will find there is a clip joiner - unplug it.
7. Use a multimeter (if you have one other wise skip to step 8) put the probes across the wires coming from the reed switch and you should find the circuit opens and closes as the washing machine lid is opened and closed. If it does not then pretty sure the reed switch is not working then follow step 8 to short it and test.
8. Another method is just to short the wires by jamming a wire across the connector that goes to the machine and NOT the connector to the reed switch
This will bypass the reed switch detection so will always be a closed circuit. But since it still has a lever door open detection system it doesn't really matter.
Try a washing cycle to see if it has fixed the problem.
If you have the means then replace the broken reed switch by buying another one from your local shop.
If your problem with the dE error is not with the reed switch then it may be with the lever system which I have no experience with.
Samsun SW51ASP top loader washing machine dE error
