Question about Amana Microwave Ovens
Can i bake cakes in my amana radarange oven model#RRL-5C MADE IN NOVEMBER 1983 SERIAL # AL52069970
    Top Expert:
  • Amana Master
  • 61,847 Answers
HOW WOULD WE GUESS . TRY IT AND FIND OUT FOR YOURSELF . THAT IS HOW WE ALL LEARN THINGS
Posted on Feb 23, 2019
SOURCE:
trintek
  • 111 Answers
SOURCE: Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
Posted on Nov 21, 2007
MicrowaveSvc
  • 9156 Answers
SOURCE: Instruction manual for 1986 Amana Radarange microwave
I think it will use a standard generic probe for the Accu-Temp. Sorry I couldn't help. Take care.
Posted on Jan 28, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: Light went out in Amana Radarange Microwave.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Nov 21, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: Need to change bulb inside Amana radarange RR1220
There is an access / cover panel on the back of the oven.
It's shown in the exploded view here.
Please unplug the oven from the wall first.
Then use a 1/4" nut driver or socket to remove the screw in the end of the lamp cover.
The bulb is behind the cover, and should be readily available at grocery stores, home improvement centers, hardware stores and big box stores like Wal-Mart.
Posted on Dec 02, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: Moved oven. Keypad can not set time. Amana RRL 9TC
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Posted on Feb 02, 2009
Door handle on Amana Radarange Model MVH100E1 came dissconnected at the bottom of handle. How do I reconnect it since it appears to have been riveted to the door?
I would use epoxy glue allow it to dry 24 hours for maxium bonding, clamp it in place for best results, otherwise the door would probably need to be replaced.
May 02, 2012 | Amana Radarange Microwave Oven
I'm trying to find a replacement glass tray for my Amana microwave oven. The model number is RRL-10TD. The date on the back of the oven is 1982.
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 11, 2011 | Amana Microwave Ovens
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
Help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
Mar 17, 2009 | Amana Radarange Microwave Oven
Good luck.
Feb 02, 2009 | Amana AMV5164 Microwave Oven
Nov 21, 2008 | Microwave Ovens
Jan 14, 2008 | Microwave Ovens
Nov 21, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
