Question about Sewing Machines
The thread bunches in the bobbin and stops the machine after two or three stitches
Is the thread in the bob in wound tight enough?
Posted on Feb 22, 2019
  • Sewing Machines Master
  • 751 Answers
Likely top thread tension is too low (or none) or top thread is being caught by debris in hook race. Remove and clean bobbin area (hook race). Could also be a damaged bobbin case. Check top thread tension by comparing foot up to foot down while pulling top thread.
Posted on Feb 21, 2019
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
SOURCE: Bobbin thread bunching
I have a Kenmore 16231 That kept bunching up on the bottom side of the material. I found to correct this problem, there is a tension adjustment under the cover on the left side of the machine ( the light is housed under this cover) I found a tensiner lever numbered 1 - 4 and if you try this adjustment on 3 or 4 this machine works great. hope this helps
Posted on Jan 05, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
  • 30 Answers
SOURCE: mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Posted on Aug 22, 2009
Thread keeps bunching up under needle plate.
hi Virginia.
you have not said what make you have.
but this is all i could find out.
Make sure your bobbin is threaded properly along with the top thread. It would help to know which machine you have. Mine has only one way to put the bobbin in so it will work okay, but I have had the thread miss the take up lever and it acted the same way (top thread). Keep trying.
Is it bunching as you first start sewing a seam? Try hold the bobbin thread and the top thread lightly when you first start your seam.
If you look at how the stitch is made, you'll see that the bobbin and top thread are interconnected, without a bobbin thread, you don't have a stitch. Check out the link below to see how a machine makes the stitch. It's pretty cool.
Are you bringing the bobbin thread to the surface before trying to sew? To do this, manually turn the wheel on the end of the machine so that the needle drops down into the bobbin race, while holding onto the tail of top thread. Bring the needle back up so that it's as high as it will go. Now pull on the tail of the top thread and it should bring up a loop of the bobbin thread. Pull up the loop so that the tail of the bobbin thread is up. As Marion said, you need to hold onto these tails when you start your seam, or the bobbin thread will get pulled down into the bobbin again and cause the snarling that you are having.
Annie
Here is a link that might be useful: Sewing machine stitch
When I have the thread bunching underneath, it is usually the upper tension that needs tweaking. Also, be sure that your needle is the right size and nice and sharp. A dull needle can really gum up the works.
When mine has done that it usually has lint under the bobbin case. Have you cleaned under and around the bobbin?
Make sure your bobbin is feeding off in the right direction.
I have just recently learned this. When you are threading your machine, make sure the needle and the presser foot are both in the up position. I am betting that would fix your problem.
I use to have this problem often. [sorry for the simplicity of this answer but it works for me] the needle goes up and down, when it starts it downward motion stop. this should be the position of the needle when you start to sew. hope this helps
or this link might help you out some more.
Thread keeps bunching up under needle plate Google Search
Dec 12, 2017 | Sewing Machines
How can I stop my material sliding around when I am sewing?
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? t
May 16, 2015 | Sewing Machines
Top thread bunches
try changing the needle--use a needle according to the fabric
being sewed
if thin fabric is being sewed try using a stablizer
rethread the machine top and bobbin--use every thread guide
make sure the bobbin is inserted correctly and turned correctly
in the bobbin case
also try adjusting the top thread tension just a little
Oct 23, 2012 | Singer 2950 Mechanical Sewing Machine
Thread on the bottom side of stitch is all bunched up
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Oct 09, 2012 | Sewing Machines
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Thread bunces up on the bottom causing machine to
I would start by looking for a problem with the bobbin tension. Do you have the bobbin threaded through the case correctly? Is the the bobbin tension set to loose? Another thing that can cause it to spool up on the bottom is if it sews a bunch of stitches all in the same spot or real close, do you have the presser foot tension to loose?
May 23, 2010 | Singer 2263 Mechanical Sewing Machine
Sewing a bunch of thread from the bottom, this stops the machine from actually sewing
Yes, it does. There are a couple of reasons the bobbin thread could be bunching up on the underside of the fabric. It could simply be that the machine needs cleaning. Take the bobbin assembly out, brush all the old lint out as best you can, reoil the machine once it's all clean, and make sure there aren't any little bits of thread caught in the bobbin assembly. Rethread the machine (carefully) and change the needle. This solves the problem usually--especially if the machine was sewing along fine and the problem develops suddenly. '
The other thing to check is your tension. It could be that the top tension is too loose. But different color thread in the top and in the bobbin, stitch a few inches (be sure to held the top and bobbin thread ends behind your needle as you start to stitch) and check. WIth the pressure foot down, adjust the tension, and stitch again. Keep stitching, checking, and adjusting until you see little if any bobbin thread on the top or top thread on the bobbin.
Another thing to reminder: use the appropriate thread and needle for the fabric you're sewing.
Let me know if this works, ok?
Robbie
Jan 31, 2010 | Elna Sewing Machines
My new sewing machine, just opened to use, is bunching thread on the underneath or bobbin side when I attempt to straight stitch. What is causing this to happen. Thanks.
re thread the top and bobbin threads
after pulling up the bobbin thread pull both threads to the back and hol them when stitching the first few stitches
with out holing the threads the machine will pull the thread into the machine and bunch the thread
Aug 24, 2009 | Kenmore Sewing Machines
Bottom of stitch is bunched with alot of thread and machine jams
Try these time savers:
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Mar 17, 2009 | Singer 3116 Simple
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
