When you put the cd in it dos'ent work
HI,
does the CD that you put in that doesn't play are the CD you use before and plays on your CD player?If yes then that is a lens issue the lens probably need replacement
try to clean first the lens of the player with a soft cloth dip in an alcohol wipe the lens do not apply too much pressure when wiping
are the CD format compatible with your player there are different audio formats which we must consider with the compatibility with the player ex..audio CD,MP3,MIDI,VCD,DVD,MP4 etc.your player must support this format to play this disk.
The primary cause of disk reading failure is the lens itself .if your CD player is more than 3 years old then it must be the lens to replace next is the spindle motor this motor is the one spins the disk the life span of this motor is 4 to 5 years this are the things to consider and you can decide which part needs relacement
thank you and good luck!
