Xfinityhttps://www.xfinity.com > support
Comcast Customer Service is here to provide Help and Support for your Xfinity Internet, TV, Voice, Home and other services.
To connect your Spectroniq PLTV 32050 TV to your Dish Network receiver and program the stations, you can follow these steps:
Connect your Dish Network receiver to your TV using an HDMI or RCA cable. Make sure the TV is turned on and set to the correct input source.
Turn on the Dish Network receiver and follow the on-screen instructions to complete the setup process.
Use the Dish Network remote to program the stations. Press the "Menu" button and navigate to the "Programming" or "Channels" section. Follow the on-screen instructions to scan for available channels and save them to the receiver.
Once the channels have been saved to the receiver, use the "Input" or "Source" button on the TV remote to select the input source that the Dish Network receiver is connected to.
Use the TV remote to adjust the picture and sound settings to your preference.
If you have any trouble with the setup process, you can refer to the user manual for your Dish Network receiver and your Spectroniq PLTV 32050 TV for more detailed instructions.
I tried the different Dae Woo codes (apparently, Dae Woo makes Trutech) and none of them worked. The last option was to do a Power Scan. From the Dish Network sight, with the TV on, first you press and hold the mode button for the apparatus you are trying to set up (TV in this case) until all of the mode buttons light up (about 6 seconds). 2nd, press and release the power button. 3rd, press the up button once every 1 second until the TV turns off - this took me around 120 depressions. 4th, save the code by pressing the Pound sign after the tv turns off. 5th, press the TV mode button and try pressing different function buttons, (i.e. up and down arrows, volume, off/on button).
