Question about The Computers & Internet
After using a VICKS rapid read thermometer I turned it off--when I turn it back on the tempt it read last appears and screen goes blank (it's new). Something you need to do to reset it to use again?
  • The Master
  • 8,895 Answers
Call or email VICKs for assitance.
Consumer Relations Line: 1-800-477-0457
e-mail consumerrelations@kaz.com
Posted on Feb 22, 2019
Slinteriors
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
  • 1684 Answers
SOURCE: Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 19, 2009
  • 5 Answers
SOURCE: the screen goes blank (black) after a few seconds.
I have one that does the exact same thing. I tested the power board and there's no voltage coming out of the 12V pins. Defective power board for sure, but good luck finding a replacement, and if so, pray it doesnt happen to that one, as it seems to be a common issue with this model. I'm doing more research as to what is failing on the board so i might perform the repair myself.
Posted on Mar 19, 2010
  • 164 Answers
SOURCE: Toshiba M300 screen turns white blank.
White screen means that your lamp (back light) is working absolutely fine, but you could have a loose connection for the data ribbon cable, which sends the images to the monitor.
Carefully open laptop to reach its lcd, there must be ribbon cable which looks like this: mrc-0069.gif
It is very sensitive so be very careful with that, very gently remove this from the chip and reconnect it.
Hope this helps, Please feel free to ask me any further.
Posted on Apr 10, 2010
  • 8457 Answers
SOURCE: screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 14, 2010
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Nov 01, 2014 | Acu-Rite Acurite Wireless Weather...
No matter how long I let it heat up never goes past 250 degrees
First, do the flames on the burners, when they're on high, appear to be normal? Or are they lower than normal, despite the burner knob(s) being turned to high? Do you turn the tank OFF after grilling each time?
If you answered yes, to the last two questions, here's what you need to do. Turn the tank valve OFF. Disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Turn the tank valve ON VERY, VERY SLOWLY, until it's completely open. Light each burner individually and turn the burner knob to high. Once all the burners are lit and turned to high, do the flames look taller than before?
If so, you just solved your problem. Remember to turn the tank valve on VERY, VERY SLOWLY each time you turn it ON.
If the above is not the problem, the grill thermostat may be faulty. To test this theory, purchase an inexpensive Oven Thermometer and place it on the grill grates, when preheating your grill. Close the lid of the grill and ten minutes later, take a look at the Oven Thermometer and compare it's temperature with the grill thermometer. If the grill thermometer is reading significantly lower than the Oven thermometer, you need to replace the grill thermometer. You can purchase one directly form Weber.
Hope this helped you solve your problem. Happy Grilling!
Feb 20, 2011 | Weber Genesis Silver B Grill
Apr 10, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
The thermometer turns red when i turn on my car, it's normally blue.. what does that mean
That's totally normal, that's just the sensors in you car making their self tests while starting the engine to ensure that they are working ok. It's just testing that the coolant temperature warning system if working ok, hence the red thermometer appearing. After that all the systems go back to normal and give you their true readings, and that's why it goes to blue, which means the engine is cold and just started. After a while when the engine heats up normally and has run for a few minutes, the thermometer should disappear completely. My 2005 toyota echo does exactly the same thing, and so do many newer vehicules. So nothing to worry about, it just means everything on that system is working fine and like it should.:)
Jul 08, 2009 | 2003 Volkswagen New Beetle Convertible
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
I have a Vicks Thermometer, the comfort flex one, and it is not working properly. Everytime I turn it on there is a small triagle on the left side... I dont have the manual, so I dont know what that means.
Your battery is too low to allow it to operate properly, according to the manual. You can use a coin to remove the battery cover in the back to see what type of battery is needed to replace. Most drug stores like walgreens, etc, carry the watch type battery.
Dec 09, 2008 | Computers & Internet
Screen goes blank with line across it
It's been rumored to turn off WAAS, as it seems to be a new satellite communication problem within the V. So far so good with mine. It appeared the screen was dead at first.
Sep 28, 2008 | Garmin GPS V Receiver
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
Blank screen
First thing is do you get the start-up screen when you turn it on?
If that appears tro be OK you may have inadvertantly changed the screen brightness.
Remove from the mount and rotate the unit in your hand to the light. Tap once on the screen and then tap where the light bulb icon is. Drag the brightness up to full scale. Also make sure it is not in night-time mode with its brightness turned way down. Not that you would probably suffer the same problem that I had but the screen will go blank and actually give you a thermometer reading if the unit overheats from being exposed to a locked car in full sun, Mine reported 52 degrees Celsius and failed to work until I cooled it down in front of the air-conditioner vents. Of course it was summer and I live in North Queensland Australia! Hope it comes good for you.
Mar 30, 2008 | Navman F20 GPS Receiver
Computers & Internet Logo
23 people viewed this question
Top The Computers & Internet Experts
Inky Fingers
Inky Fingers
Fred Sops
Jorge Smith
Jorge Smith
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
