Call them here.https://www.locksmithledger.com/company/10174616/sisco-inc
SOURCE: what key blank fits a brinks 5575 safe
My program shows 3 possible key blanks if it is a tubular key that fits this safe then the blank # would be Ilco 1137B, If your key has cuts on both sides of the blade then it would take an Ilco 1626, If it has cuts on only one side of the blank then it would take an Ilco 1531 I hope that helps if you have any more questions you can contact me thru my website at www.jambrilocksmith.org Bob
SOURCE: Are all bunker hill safe keys the same?
Never!.............sodeep (unless you happen to be the lucky one in a million)
SOURCE: LOST COMBINATION FOR MY SAFE SERIAL #156880S-R /MODEL 5054
http://www.sentrysafe.com
the instructions are located link above.
mj
SOURCE: Besides the phone number or
Brinks safes are very reliable and secure, Unfortunately there is no way of recovering the the combination of the same without speaking with manufacture. Now you could do it the old fashion way that is to listen to clicks from the combination lock while moving the nob, However this takes alot of practice. The only the I would suggest to do is to speak with the Manufacture. I do appoligize once again and I hope you have better luck. Have a good day
SOURCE: i locked my safe numbers
I'm
sorry if I can not give you the exact combination and I'm sure no one
does. Because that is what Sentry Fire-Safe is all about, secrecy.
However,
the best solution for your problem.... to be able to acquire the right
combination for your safe.... is to call the attention of Sentry Safe
Shop
You must call (800) 828-1438 for combination retrievals.
or
send a notarized letter stating you are the owner of the safe, personal
information, model and serial number of your safe and must indicate the
method on how you will receive the combination.
See further details from this link
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Please post back for any clarifications and let me know so I can help you further.
Thanks
Alpug
