Question about Sharp Aquos Televison & Video
What screw size will I need to attach the base to my Sharp Aquos 65SE94U? I am going from wall mount to Base stand and I need the missing 12 screws.
  • Sharp Master
  • 1,527 Answers
Base screw size for a sharp aquos lc60le600u - Fixya
www.fixya.com/support/t21164248-base_screw_size_sharp_aquos_lc60le600u
Nov 4, 2013 - Once I had a chart of the screw sizes but I'm not sure that ... If you want you can callSharp when they open tomorrow morning 8:30 AM central ... What size screws do I need for TV stand model no ...
Oct 11, 2017
What is the vesa wall mount pattern on a sharp lc ...
Jan 25, 2014
SOLVED: Hi. I need the 4 screws to mount the TV ...
Jul 10, 2010
aquos screw size Questions & Answers (with Pictures)
Jan 21, 2010
More results from www.fixya.com
Missing: 65SE94U
Posted on Feb 20, 2019
  • 5 Answers
SOURCE: PROTRON STAND
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
Posted on Jun 10, 2008
  • 148 Answers
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
Posted on Feb 05, 2010
budmrtn
  • 11361 Answers
SOURCE: I have and AOC 32
Metric M4, but more likely to be M5 or M6 which you can try difference length for about 35 cents each at HD or LOWE.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 08, 2010
budmrtn
  • 11361 Answers
SOURCE: Hi. I need the 4 screws to mount the TV stand to
They are metric screws, you van get them at Lowe or HD, try M5 or M6. they are about 35cent each so you can try difference length.
Posted on Jul 11, 2010
  • 298 Answers
SOURCE: i need to know the
What is the model number of the television?
Posted on Aug 31, 2010
I lost the 4 short screws for my sharp aquos tv stand model lc 52d62u.i need to know the exact size to replace them.
Google is your friend
This is very late (4 years) but may help someone some day. For my Sharp LC52D64U stand:
Arm to base: 4 - M6 x 35mm
TV to arm: 4 - M5 x 16mm
BTW: base model CDAI-A418WJ36 fits just as well as the original CDAI-A376WJ32 and is usually cheaper on ebay.
http://www.avsforum.com/forum/28-tweaks-do-yourself/1004261-missing-sharp-aquos-screws-help.html
Jun 21, 2016 | Sharp Televison & Video
I just got this as a gift and it only came with screws to mount it to its base. I have a TV stand that has a TV mount attached to it.
Google
Make model wall mounting screws and then look at the link to Amazon.
They probably will be M 8, 10 or 12.
Jan 31, 2016 | Televison & Video
NEED BASE STAND FOR A SHARP LC-46SV50U
Go to shopjimmy.com and get a universal stand. It attaches to the back of the TV just like a wall mount.
Mar 30, 2013 | Sharp AQUOS LC-46SV50U 46" 1080p LCD TV -...
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
How can i get the stand off of the tv to hang on the wall?
Before detaching the stand, unplug the AC cord from the AC INPUT terminal. Before performing work spread cushioning over the base area to lay the TV on. This will prevent it from being damaged.
With the hex key that came with the television stand remove the four screws from the bottom back of the television and remove the stand.
If you also wish to remove the post from the stand base unit you can remove the four screws that attach them.
Jan 03, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
Taking off stand from LG tv to mount on wall
I work on TVs and the amount of screws in the back is crazy.
find a place to lay the tv down on the screen, use some pads and a blanket to prevent scratching or cracking screen. your couch or bed may be a good choice, but make sure it is stable. let the stand hang over the edge with no weight on it. now look for 6-8 screws per per leg of the base. depending on the size of your tv. these are usually the larger screws on the tv and attached to the frame of the TV. remove these screws in the base and slide the base out.
your manual should also have a brief description of base removal as well. dont worry about taking out the wrong screws, you can put them back in it is not the right screw. with tv on its face, no parts will fall out. hope this helps.
Apr 08, 2009 | Televison & Video
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
