Go-go elite traveler plus hd 4-wheel mobility scooter with brand new batteries
SOURCE: lost the main key and can't find the second key.
most keys for that type of scooter are the same, (not like a house or car key) call Pride 1-800-800-8586 for replacement or any Pride dealer can help you. Also, a paper clip can jump the ignition by placing it in their to get you around temp.
SOURCE: yamaha 50 vino - starting problem
If it sat for a year without Sta-bil in the gas it is probably gummed up and you will have to remove the carb and clean the gunk out of the inside of it and check out all the passageways to make sure they are clean and open
SOURCE: Error code F2.Q1
One thing to do before you start disassembling the door:
The touch pad connects to the turntable and other functions via a pair of connectors just to the left of the lights. Since these are located directly above the stovetop's cooking surface, your problem may be moisture accumulation on these connectors.
1. Remove the bottom panel; and locate these connectors.
2. Disconnect and clean both sides of these connectors with electrical contact cleaner.
3. Reconnect and test.
Good luck,
m
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Testimonial: "thanks for the answer so quick il phone them tomorrow"
SOURCE: T Maxx 3.3 full throttle issues.
Sounds like either the slipper clutch is too loose or the clutch shoes are not engaging the clutch bell.
