I have a SHARP television and the sound and picture go off
Ron
A few minutes after I turn on the television. This happens every time I turn on the TV. I can restart the TV immediately after it goes off, but it only stays on a few minutes.
I have had exactly the same problem. Sounds daft but by not using the remote, and only using the power on/off switch on the TV itself, it is working perfectly...no idea why
Use the remore for changing programmes etc but not for on/off
Try it anyway because I know how annoying this is
sounds like you have a bad panel. This ussually happens when a backlight lamp has gone bad and the inverter board senses this and sends a signal to turn the backlight off.
does it tick all the time are just a few minutes and can you turn it off and back real qiuck and see or hear high voltage come on are see a flash is sounds like you have what is know as startup are shutdown circuit trouble
Comment by Guest, posted on Oct 25, 2008My
Aquos has the same problem. I'm not sure how I discovered this, but
when I lean the TV forward and hit the power button it will turn on
every time. If the screen blacks out and I don't lean it forward when I
hit the power button, the screen will just remain blank. It is very
weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
I have a sansui 19" LCD TV+DVD I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there. The set is not yet 2 years old.
