SOURCE: Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
SOURCE: bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
SOURCE: Protect at high volume
No such thing as too much power unless you have a faulty alternator/voltage regulator.
The hundred amp fuse at the battery is better than none but I would replace it with a 50 Amp, that fuse is really only protecting the power wire from grounding out and burning.
The gains are irrelevant, all they do is attenuate the input.
Set them so you cant hear any amp hiss or noise on quiet passages of music or between tracks.
Make sure your not starving the amp for power. Start at the battery connections and work your way back to the amp, inspect all connections for corrosion and make sure they are tight.
Check the ground wire . It is just as important as the power wire!! Try to ground it as close to the amp as practical, scrape off the paint down to the metal use a oversize screw with a star lock washer and a ring terminal.
Make sure that your power wire and ground are at least 8 gauge.
Next on the list is your speakers and related wiring, check to make sure that your impedence is not too low for the amps rating. and that the wiring is correct and at least 16 gauge, 12 is better.
. You can check the speakers impedance with a Ohmmeter, it wont be exact but it should be close +/- .5 Ohm If you are bridging, make sure the speakers are wired in parallel + with+ and - with - .check the amps rating and bridging configuration, it's normally left positive, right negative, but check!
Having done all the above, and you still have a problem only two possibility's left, Defective speakers or the amp. Check with a qualified installer, buy him lunch, you'll get good advice forever.
I hope it helps. Regards Paul
SOURCE: Receiver goes into protect mode when hitting certain volume level
There is a problem in one of the output channels of the amplifier. That is the only reason it will do this. I work at an authorized Denon service center and have seen this problem several times, but it has never been the same thing that causes it. It has always resulted in extensive troubleshooting to find the problem. One time it was a capacitor in the pre-driver circuit for one of the channels, another time it was a transistor in the same type of circuit. I can not remember all the other causes. But without the proper tools and the knowledge of how to troubleshoot an amplifier circuit you will never figure it out.
Since this is an older model, more than 3 years old, it is no longer under warranty. They get a 2 year warranty from Denon. You can take it to any service center that works on stereo equipment and they should be able to fix it for a reasonable fee. Probable around $125 to $150 depending on their rates. It may seem like a lot, but it is much cheaper than buying a new one.
Since this is really the only option for you, unless you have the tools and knowledge, a FixYa! would be much appreciated and appropriate.
If you would like to troubleshoot it yourself, let me know, I have the service manual in PDF and can email it to you if you like and help you with troubleshooting it. But be aware, it is not an easy job.
Dave
SOURCE: !!!red protect light is on!!!
Hello beaugarcia26,
Unless the amp itself is defective, there's a short or ground somewhere.
First disconnect the speaker wires and RCA (or high level) inputs, leaving just ground, remote turn-on and power leads connected. Then see if the amp powers up normally. If it doesn't check the ground with a multimeter and make sure it is good. If the amp powers up normally, check the speaker, speaker wires and inputs for shorts or grounds.
Hope this helps.
