I
IGBOEGBUNAM ANTHONY CHUKWUKA Posted on Feb 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i clear H4 error code on sharp photocopier AR 6020
Anthony Karuku
Level 2:
  • Sharp Expert 268 Answers
  • Posted on Feb 26, 2019
Anthony Karuku
Sharp Expert
Level 2:
Answers
268
Questions
Helped
104849
Points
615
Press #, interrupt, C, interrupt. Display must go off. Enter 14 and press copy button. You're good to go. If the problem comes back, check if power supply is of normal rated supply, check fuser lamp and thermistors n thermostat if they are OK.
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Jun 06, 2008
SOURCE: Sharp AR-M237 Error Code H4-21
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
If the error code recurrs ther are other problems.
Anonymous
  • 62 Answers
  • Posted on Jul 30, 2008
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Anonymous
  • 3 Answers
  • Posted on Feb 03, 2009
SOURCE: error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Warrick Lee
  • 32 Answers
  • Posted on Mar 25, 2009
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
rezazadeh
abbas rezazadeh
  • 328 Answers
  • Posted on May 29, 2010
SOURCE: Sharp AR-123E, H4 error code, printer not ready
it doesn`t need to change board. code 14 clears.
HOW DO I CLEAR THIS ERROR CODE H4-00 ON PHOTOCOPIER SHARP: AR-M276
http://www.fixya.com/support/t5397165-got_h4_00_problem_in_ar_m276_photocopy
Quoting: "Press # * C *, then enter 14 and press start, then 1 and start, then clear.
Posted on Jul 27, 2010"
23helpful
6answers
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
18helpful
3answers
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
3helpful
9helpful
2answers
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
20helpful
4answers
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
2answers
Error h4
franklin
4helpful
3answers
Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
