SOURCE: Problem connecting Samsung DVD-HR737 DVD recorder to Set Top Box
I had the same problem, if you go through the channels from your DVD-R remote it should give you the option AV-1 and then AV-2 ? on mine it's AV1 (test it out first and you have to watch what your recording) then it should record from the cable box
worth a try?
SOURCE: audiosonic 51cm tv, will a HD set top box work?
nope standard def should though. will say tv does not support hd channels
SOURCE: I have a 42 inch plasma and teletext wont work any
A factory reset made teletext available again on digital channels.
When on standby, push on remote in quick succession <info><menu><mute><power> buttons. Follow onscreen menu to option 12 (reset) and select. Be aware that you will have to tune in all analogue and digital channels again.
