Powerware 9120 UPS System Logo
Shannon Posted on Feb 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to repair my Powerware 9120. A while ago it was gracefully shut down after an extended outage and when we turned it back on it emitted a flash of light and a bang through the air vent. I assumed it was probably unhappy about the poor state of its batteries, I took them all out and recycled then and am now trying to get the ups going again. I replaced a fuse (f3) that had blown (5 meg ohms resistance). No skidmarks I can see, haven't ruled out a dry cap. I've tried to power it up, without batteries, it's making a ticking noise towarsds the front of the board and the TO-220 over by U06 is getting a bit hot... U06 would be about where to the ticking noise is coming from too. At a guess, it's part of a switch mode supply and something has gone wrong. Nothing else in the unit is getting hot so I don't think the power supply is driving anything Anyone got any pointers for where to start?
matt
Level 3:
  • Powerware Master 1,666 Answers
  • Posted on Feb 20, 2019
matt
Powerware Master
Level 3:
Answers
1666
Questions
Helped
695435
Points
9998
5 Related Answers
Anonymous
  • 82 Answers
  • Posted on Sep 25, 2007
SOURCE: UPS TRIPS AFTER 30 SECONDS
dear, This problam is related to battery and i am sure your battery is faulty pls replace it.
Anonymous
  • Posted on Jan 10, 2008
SOURCE: power swith ic went bang!
unfortunately these boards are now obsolete, it may have damaged the bridge rectifier
Anonymous
  • 563 Answers
  • Posted on Apr 01, 2008
SOURCE: Benq PE8700 - Won't Power Up
Hi there
Trust me that the Mainboard needs replacement.
I am very familiar with the PE8700's as I am a ASP Technician for BenQ.
Visit www.BenQ.com and look for the link to your country - you should be able to allocate a Approved Service Provider.
Must warn you that the Mainboards on these models are quite expensive.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 03, 2008
SOURCE: shuts off while driving. no fuel pressure. pcm fuse blows/ fuel pump relay inserted.
Sounds like the fuel pump is shorted.
Alan Hood
  • 195 Answers
  • Posted on Mar 03, 2009
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
My Powerware 9120 2000 has low power alarm and shutdown at 50% charge
A Powerware 9120 2000 is an uninterruptible power supply (UPS) device that provides power backup to connected devices in case of power outages or other power issues. If the UPS is shutting down at 50% charge and showing low power alarm, there could be several possible causes:
  1. The battery is failing: The UPS is designed to shut down when the battery charge reaches a certain level to prevent damage to the battery. If the battery is failing, it may not be holding a charge and may need to be replaced.
  2. The battery is not compatible: Make sure that the battery you are using is compatible with the Powerware 9120 2000 UPS. Using an incompatible battery can cause the UPS to shut down or display error messages.
  3. The battery cable is loose: Check the battery cable connections to ensure that they are tight and secure. A loose battery cable can cause the UPS to shut down or display error messages.
  4. The UPS is overheating: Check the UPS for any signs of overheating, such as a hot feeling on the top of the unit or a burning smell. An overheating UPS can cause the UPS to shut down or display error messages.
  5. The UPS firmware is outdated or corrupted: Check to ensure that the UPS firmware is up to date and not corrupted. Outdated or corrupted firmware can cause the UPS to shut down or display error messages.
If none of these solutions solve the problem, it's recommended to contact the manufacturer or a professional technician for further assistance. They will have the knowledge and expertise to troubleshoot and diagnose the issue with your Powerware 9120 2000 UPS.
Can I replace the fan in a live powerware 9120?
hey dude your problem is so simple..below are my solutions.
if you already secured the fans for the replacement then its easy for you to do it, try to totally shut down your UPS removing the input and battery supply. avoid replacing the fans with power, its to dangerous. it consist of almost 400VDC inside in it.
call me if you want +63923 3024 585
2answers
I have a Powerware 5125 that I just replaced the batteries on. Now I get NO power to the unit when trying to turn the unit on. I put the original batteries back in and the same thing is happening. All...
I urge you to contact Eaton: Toll Free: 1 800 356 5737
E-mail: [email protected] They bought Powerware about 6 years ago and have a full team of service personnel familiar with the 5125.
2answers
When i power on the ups it show site fault on the display,i checked the earth wire is ok . what can it be a problem?
Hi, here is the documentation page for the 9120 where you can find the manual: http://powerquality.eaton.com/Products-services/legacy/9120-info.asp You can also contact customer support 800 356 5737 or [email protected]. You may recognize the product as the Powerware 9120 but Powerware was bought by Eaton a few years ago. The customer support team is most ex Powerware and are familiar with the 9120.
Uninterruptible Power Supply problems. My uninterruptible power supply (UPS) is not backing up during a utility power outage.
First, we do need to full charge it. Then see what's being able to pick up a load of this Ups power or not? If not then it means something is wrong with this Ups. Please put this change.
2answers
Replacement fans for powerware 9120
A good electronics supplier should have. Get the correct voltage and size, and get one with the largest CFM available.
2answers
1helpful
2answers
Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Top Powerware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
