Computers & Internet Logo
Crystal Lumley Posted on Feb 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have someone tried to reset my Acer Aspire One series model kav60 and I don't know what happened but obviously it didn't work and now my screen says no bootable device insert boot disk and press any key what do I do about fixing this or resetting this notebook
Larry Ng
Level 3:
Top Expert:
  • Acer Master 14,598 Answers
  • Posted on Feb 20, 2019
Larry Ng
Acer Master
Level 3:
Top Expert:
Answers
14598
Questions
0
Helped
3278869
Points
66616
I had ? someone try?
no problem stated before "SOMEONE" got hands on it.
post problems first then actions taken 2nd please.
first tell what the word RESET means.
PCs have vast things inside that RESET.
of you mean go back to day one with the original new OS like day one new, sure, that is called a factory reset.
or factory OS recovery is the better, way to say this.
PCs come new, (modern) with a hidden recovery partition
that works great of the PC was never attacked with OS upgrades
or new HDD (hard disks drive)
first off fixya is not acer.com only they are and only they have your support, drivers , software and books covering RECOVERy.
lets go there now and read you chapter called that.
the first question is country , I will do wild guess and pick USA
http://www.acer.com/worldwide/support/
then I go here.
kav60 is really a Aspire One AOD250
ok, it tells you that there.
the support page asks for class firsts.
omg I found it, on that hard site to navigate.
its not under laptops/note boots but chromebooks.
bingo.
https://www.acer.com/ac/en/US/content/support-product/1113?b=1
so we now RTM we read the recovery chapter.
10 year old laptop , most this old have a bad HDD
I an real shop we test the HDD first.
or go broke watching new OS die on bad hDD. all day long.
pdf page 19
if no recovery disks in hand
we read page 29
(no disks) recovery.
step on turn on D2D recovery in BIOS, per your manual.
then power on and hammer ALT +F10
you are now in the recovery (magic) partition loading fresh OS.
page 30
"Important! This feature occupies 6 GB in a hidden partition on
your hard disk?'" that means the HDD must not be bad.
that
sop tha
5 Related Answers
Anonymous
  • Posted on Jul 10, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Aug 06, 2009
SOURCE: acer aspire one
Its possible the computer is trying to boot from another device, as the computer starts up hit the F12 key, this should bring up boot options, select HDD if it's in the list.
If not hit F2 as it starts and enter the BIOS, look for the boot option and set the HDD as the first boot device, hit F10, save the changes and exit.
The computer will restart and hopefully boot into the operating system
Please post back if you need anymore assistance.
Regards.
Anonymous
  • 5 Answers
  • Posted on Oct 13, 2009
SOURCE: Acer aspire one mini notebook. NTLDR is missing..
If you don't have documents, pictures, etc on the hard drive that you need to backup, try running system recovery by doing the following (not sure if this works on the version with a solid state drive):
1. Turn on the computer
2. Press and hold Alt + F10
3. Click on Restore System to Factory Default
4. Ensure the netbook is plugged into AC power instead of running off the battery and click OK
* This will return your netbook to the condition it was in from the manufacturer.
Anonymous
  • 531 Answers
  • Posted on Aug 27, 2011
SOURCE: my acer aspire 5551 laptop isn't starting up its
Hi
Check underneath and use a small screwdriver to open the small rectangular panel with the image of a stack of CDs near it. This is where the Hard Drive sits.
Check to see if the Hard Drive is properly fitted properly docked into its socket and screwed down or held down properly so it is immobile during use.
If this is not the problem, tap the Fn + the correct function key to enter the Boot Menu at Start Up and use the keyboard arrows to select the Hard Drive boot option.
Make sure there is no CD or DVD in the Optical Drive.
If none of these is the problem then, regrettably, your hard drive may have failed, so remove it and test it in a hard drive dock or an external 2.5" Hard Drive Enclosure.
If it has failed you will obviously need a new hard drive, bootable operating system disc, drivers disc and programs and security software to reinstall everything to the new hard drive.
Unfortunately, any data on the old drive will be lost.
It is very unusual for a Hard Drive to fail suddenly without some prior warning or signs of failing (the only realistic way would probably be through a drop, severe knock, serious mains power surge or mains power cut, incorrect shutdown procedure, or sudden disconnection of the power cable during use).
Back up regularly to an external storage device and do not ignore any warning signs. Also plug all computer equipment to the mains via a Surge Protector/Suppressor to prevent damage from power surges or fluctuations.
I hope this helps
Anonymous
  • 32281 Answers
  • Posted on Jan 22, 2012
SOURCE: acer aspire one 722 model p1ve6 no bootable device
Re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
2answers
I need a manual for a Acer Asprie one KAV60 notebook
try here https://www.manualslib.com/products/Acer-Aspire-Notebook-Series-4252507.html
I get a message on my ACER Aspire Laptop7551 Series, which says Enter HDD User Password. What do I do?
Well, obviously someone has put a password lock on the hard drive and if it wasn't you and you don't know who it was or know the password your only option is going to be to replace the hard drive. There are places that can unlock a drive but you have to prove to them that is yours and they are expensive. Cheaper to just replace the HD
ON THE ACER ASPIRE ONE NETBOOK HOW R WHICH COMMAND DO YOU PUSH FOR IT TO RESET F WHAT? HELP PLEASE MODEL KAV60
Hi
please tell us what you are trying to reset so that someone may be able to help you
5helpful
I am trying to get updates for my drivers on my Acer aspire one model #KAV60 but when i go to website for acer my model number is not listed.
Apparently the KAV60 is actually Model No AOD250
Try this link:
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
1. Select Netbook from Product Family.
2. Select Aspire One from Product Line.
3. Select AOD250 from Model.
4. Select your Operating System from the O/S dropdown.
5. Download your required driver.
BD
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
