Question about Korg Music
KORG KA320 switching adaptor - does this unit have a fuse and if so, how do I replace it?
  • Korg Master
  • 3,775 Answers
The answer is no so you cannot replace a fuse that dies not exist. Time to replace the item.
Posted on Feb 20, 2019
Testimonial: "Thanks. Do you know if there should be a male pin in the barrel of the plug to slip into the female socket in the keyboard? I've tried with an adaptor without a pin and it won't work."
SOURCE:
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
I have s korg 3200 d and the effects button is not working is there anything I can do to try and get it working on my own?
You can try a full reset (instructions in your manual) and if it's a software glitch that should fix it. If it's the switch itself, you have to disassemble the unit to get to it to try to clean it or replace it.
Sep 25, 2015 | Korg Music
Im not getting power to my Korg X5 synthesizer
Check to see if the adaptor is working. If it is, take the unit to a service center. Do not try to fix electrical problems if you don't know what you are doing.
Dec 03, 2014 | Korg Music
When I turn on my KORG C15S often it blows 1A Fuse. It seems as a power supply unit problem. Any suggestion for repair? Please help
It's likely capacitors discharging, then re-charging during power-up weakens the fuse element. Try a slightly bigger fuse (1.5A)
Also, if you have some contact cleaner (NuTrol is best) try cleaning the power switch as intermittant action can confuse switching supplies.
Nov 10, 2014 | Music
How to change a fuse on a korg Sp-250
There is no fuse inside SP250. If the unit can't power ON,there maybe damage to the adapter,adapter cord/connector,or broken fuse inside the adapter.
If adapter is in good condition, then the damage is inside SP250.
The possibilities are on regulator section.
Check all parts in this section (figure 1).
Also maybe there is a broken soldering joints at DC input socket.
change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-0.jpg change-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-1.jpgchange-fuse-korg-sp-250-fuxmm42irvf2p03kxwfdv02c-3-3.jpg
Jun 01, 2014 | Korg SP-250
Moving to Canada Korg M50 - 220V to110V ?
110 will not damage it, just will not work, if built in power supply should say on the rating plate next to power input the voltage it is able to take, a lot of units are rated 110-240v some will have a small switch to change over from 110 to 240. Other than that, you will need to get a step up unit to supply 240 from 110 just a small transformer unit.
Mar 06, 2013 | Korg M50 61-Key Music Workstation Keyboard...
Hi i got the korg pa50sd when i swith it on it shows me korg pa50sd boot loading files then this goes off, still the light on display is on but blank display with nothing on it ,. i was trying to find any...
NOT a fuse... thaat person knows nothing. There is something wrong for sure. Check if one of the buttons or keys MIGHT be stuck down (depressed). Sometimes the units check that all the control buttons are up and they don't really tell you why they fail to start. Beyond this a repair shop is in order.
Jul 11, 2011 | Korg PA50SD Pro 61 Key Keyboard Bundle
After having been in safe waterproof storage during cyclone season I,ve unwrapped my korg pa 500 and plugged it in but it doesn,t boot up .The sreen is lit well with simply "Korg"...
First thing... make sure you are using the KA320 power adapter with it. We will work from there.
The unit probably is sensing an error of some type. Check these things: That NO key or button is STUCK down. Next, one could try reseating the memory sticks if you have expanded memory.
Let me know if you find a button or key is stuck down (not uncommon when unit has been wrapped) or you are using the wrong power adapter.
Jun 10, 2011 | Korg PA500 Professional Arranger 61 Key...
My korg kp3 has worked perfectly for the last three years. The other day when I plugged it in and engaged the power switch, it would not turn on. I haven't dropped the unit or the power supply and...
I agree, it's probably either the power supply (has it a fuse?) or the power connector or the power switch or an internal fuse. Probably a simple fix.
Oct 31, 2017 | Korg KP3 KAOSS Pad DJ Effects
Burnt ic chip on Korg microKorg pcb.
Hi Mate, I have the exact same problem, casued by wrong adaptor being connected by accident, did you manage to find what the code is on the IC5 chip ?, I can see NSV, but there is another letter or number before it but cant make it out as that where its burnt.
Jan 17, 2009 | Korg Music
Music Logo
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
