Question about Sony Cyber-shot DSC-T900 Digital Camera
HAI GOOD DAY I HAVE A SONY CYBER SHOT DSC-T900 CAMERA.THE PROBLEM IS WHEN I WAS TRYING TO SWITCHING ON THE TOUCH SCREENSCENCE IS NOT WORKING AND UNABLE TO OPERATE
  • Sony Master
  • 1,527 Answers
SOURCE: Sony Cyber-Shot DSC-w5 "MEMORY Stick LOCKED" ??? please help!
take your memory stick out of your camera and theres this sliding thing on the back...slide it so that its not on the lock side? does that make any sense? well..good luck!
Posted on May 14, 2008
  • 36 Answers
SOURCE: Sony Cyber-shot DSC-W30 Digital Camera
If you want to reset DSC-W30, press Menu and go to Initialize, select it and press OK
Camera will be RESET and go to factory default settings.
Posted on Feb 10, 2009
ripleymojica
  • 643 Answers
SOURCE: My Sony Cyber-shot DSC-W200 flash has stopped working and when I try to reset it it tells me that flash cannot be reset. What can I do?
its circuit error need to replace flach unit
Posted on Jun 01, 2009
AdiIngel
  • 87 Answers
SOURCE: Cyber-shot DSC-T70 Digital Camera: My Sony Cybershot dsct70 touch screen vibrates whe...
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on May 26, 2010
AdiIngel
  • 87 Answers
SOURCE: My Sony camera vibrates
Change language to english
Touch HOME to bring up the menu. Select the toolbox icon. Select the last item on the menu.
May 03, 2012 | Sony Cyber-shot DSC-T900 Digital Camera
I got a sony cyber-shot dsc-t900 what is error 61:10?
The error is: E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
Here are some things that are reported to work:
Reset the camera:
Home>Settings>main settings>Initialize>ok
If that doesn't work give the camera bottom a couple of slaps against the palm of your hand or strike the bottom against a book to knock the lens mechanism back in place. Be resonable with the force, you don't want to break the thing. It may take a half dozen wackings to get things settled.
Hope that helps,
BAX
Feb 24, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Can,t burn video dvd from videos taken on dsc-T900
You need a dvd video burning program on your computer. Do you have one?
Jan 12, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
My DSC-T900 keeps turning off
How often and how frequent does it shut off? As soon as you turn it on? How long have you owned it and how long have you had this problem? Most likely you are going to want to send the unit in for repair you can do that at this link:
https://eservice.sony.com/webrma/web/index.do
Thank you,
Lee
Dec 08, 2009 | Sony Cyber-shot DSC-T900 Digital Camera
How to connect Sony Cybershot T900 to usb port
reference page 44 of the manual for step by step instructions on connecting your t900 to the computer.
http://www.docs.sony.com/release/DSCT900_EN_ES.pdf
Thank you,
Lee
Nov 11, 2009 | Sony Cyber-shot DSC-T900 Digital Camera
Where to connect the usb cord on a DSC-t900 camera?
Here is how to hook up camera to computer.
Good luck and please rate
Sep 23, 2009 | Sony Cyber-shot DSC-T900 Digital Camera
Hai sir camera switch on that display will
if so then there may be a problem with the software. do a firmware upgrade then try switching on. make sure the battery is full.
Mar 09, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-T900 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
