Question about The Computers & Internet
OCE PLOTWAVE 300 WILL NOT COMPLETE STARTUP IT WILL GET ABOUT 3/4 THROUGH AND STALL UNTIL THE SCREEN GOES TO SLEEP MODE. WHAT CAN I DO?
WAS GIVEN TO ME AND HE SAID IT NEEDED A NEW HARD DRIVE.
    Top Expert:
  • The Master
  • 60,369 Answers
GO INTO SETUP AND TURN SLEEP TIMER OFF
Posted on Feb 21, 2019
  • Bill Ory
    Bill Ory Feb 21, 2019
    Sorry Mr. Ray it will not finish start up so i cannot get to the area of the program to do that.
4 Suggested Answers
SOURCE: oce plotwave 300 error 8513
Dear Sunilkudal20,
the error code referes to an electronic failure in the fuser section.
  • You can try to reset the system by turn the machine off and on.
  • Check if there is no media is in the fuser section.
If this is not solving the issue, I advice you to contact you local service organization.
If you leave your country of origin, email adress and / or your telephone number, I can ask a colleque to contact you.
Kind regards,
Jack de Weirdt
Oce Technologies B.V.
The Netherlands
Posted on Aug 01, 2011
rsatishniki9
SOURCE: oce plotwave 300 error maintenance
Error Code 15709 is coming frequently... what should i do for this? please do the needful...
Posted on May 24, 2012
SOURCE: Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
Posted on May 03, 2013
OCE PlotWave 300. Error 8130. Hello, OCE PlotWave 300. Error 8130. What it for an error and how to get rid of it?
Fuser Temperature Protection Circuit Failed. Turn off the printer completely. Power off in front, and turn off main power at right, rear, bottom and unplug from the wall. Open up the fuser and take off the right hand cover. This is High Voltage. If you are uncomfortable with risking your health, do not proceed further. You will see 4 connectors (black, usually but with red insulators) that plug into the right hand side of the fuser. Unplug them and check the connectors as well as test if they are seated correctly. Ensure the red insulating jackets are pushed toward the connectors. IF everything looks OK, and the printer still exhibits this error code you will have to call an authorized Oce service technician.
Jun 07, 2018 | OCE Office Equipment & Supplies
Hi i have a problem with oce plotwave 360 give me an error 22552 we change the sd card but still have the error
Hi i have a problem with oce plotwave 360 give me an error (NO COMMUNICATION WITH CONTROLLER - 95) please help me wath i need do
Apr 19, 2015 | Office Equipment & Supplies
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Jul 31, 2014 | Oc Plotwave 300 Developer
OCE PLOTWAVE 300 ERROR CODE 8510
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL
benztirage@yahoo.fr
Jun 27, 2012 | Office Equipment & Supplies
OCE Plotwave 300. Error Code 8515\printer
The middle NTC in the fuser is broken. These are ceramic thermistors and extremely fragile. Only replace if you know what you are doing. Otherwise call your Oce technician.
Mar 11, 2012 | OCE Office Equipment & Supplies
OCE plotwave 300, error code 22509. Printer won't print.
PLC Connection lost. Get your Oce technician to upgrade you to the latest supported software level.
Oct 31, 2011 | OCE 3140 Copier
Oce plotwave 300 error maintenance and troubleshooting manual
Jan 27, 2011 | Office Equipment & Supplies
OCE Plotwave 300. Error Code 22701\printer.
Dec 10, 2009 | Office Equipment & Supplies
Computers & Internet Logo
Top The Computers & Internet Experts
Inky Fingers
Inky Fingers
Fred Sops
Jorge Smith
Jorge Smith
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
