SOURCE: LOGITECH BLUETOOTH MOUSE
Normal
0
Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth
Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard
(Usually located on the under side of your keyboard) this allows Windows to see
the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To
Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device
Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and
click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth
Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if
you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back
and click Next again.
Once the Passkey is entered, the Keyboard should be
connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
SOURCE: what is the default code to pair a bluetooth with a lgcu920
The Default code for my Lg Vu is 0000 so i assume it shall be the same for yours.
SOURCE: Forgot Lock Code - Samsung m500 Cell Phone
try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
Turn on the Bluetooth
In Bluetooth Off mode, press and hold the Bluetooth button for about 5 seconds until a beep sound is heard and the Bluetooth button backlight flashes blue.
Press and hold the Bluetooth button for about 7 seconds to change to
Bluetooth pairing (linking) mode. The Bluetooth button backlight will flash blue and red. then go to the Bluetooth settings on your phone and select it there and enter 0000 for the default password
Then go to the bluetoothT
