Changed batteries in remote, now remote don't work and manual power touch pad doesnot work.
SOURCE: Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
SOURCE: getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
SOURCE: Toshiba 36HF73 tv with remote (CT-90047). Remote doesn't work.
you just may have a bad remote . remotes go bad in strange ways sometimes messing up a program for just the tv and all other things iits programed for are fine . the recever in the tv is rock solid i have NEVER had one go bad on a modern tv (tv made in the last 20 years) try a new remote and enjoy............. Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
SOURCE: my toshiba laptop cursor doesnot move when i touch
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
