Hp pavilion g series
SOURCE: Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
hp pavilion zv5000 battery Compatible with Code:
SOURCE: XP on HP Pavilion dv2000
First of all, this Notebook is installed with SATA Hard Drive and the drivers for the SATA Hard Drive will not be available with retail versions of Windows XP by default.
I recommend you to try using different OEM versions of XP to install in your Notebook which should work.
Since the Notebook is preinstalled with Windows Vista, the XP Drivers for this Notebook are not directly available from HP.
I had searched some for you which should work.
Download the Drivers one after the other and save them with the name along with the Softpaq Number like the example given below :
Microsoft UAA_33566.exe
So that it will be easier for you to save them and identify.
Save the drivers in one location in the Notebook and double click them once the download is completed.
Make sure that you install the Microsoft UAA Drivers before installing the Audio or Modem Drivers.
Make sure that you install them in the same order I had provided them below :
You need to download the Intel Chipset Drivers for your Notebook from the link below :
http://downloadmirror.intel.com/16023/a08/infinst_autol.exe
Microsoft Universal Audio Architecture(UAA) drivers for High Definition audio :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
Conexant High Definition(HD) audio :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
As the Notebook is installed with Intel graphic Card, you need to download the Drivers for the same from the link below :
http://downloadmirror.intel.com/16944/a08/win2k_xp14363.exe
Download the Ricoh 5-in-one Card Reader Driver from the link below :
ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37712.exe
Download Intel PRO/Wireless Drivers from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34489.exe
As I am not sure whether your Notebook is installed with Intel or Realtek Ethernet card, I am providing both the drivers:
Intel Ethernet Drivers :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33574.exe
Realtek Ethernet Drivers :
http://drivers.softpedia.com/progDownload/Realtek-RTLRTLRTLRTL-Driver--WHQL-Download-33009.html
You can also try downloading the Marvel Youcon Ethernet Drivers if any of the above provided drivers did not work :
ftp://ftp.hp.com/pub/softlib/software10/COL24713/gs-63707-1/Marvell_Yukon_LAN_Driver_6.36.0.0.exe
Downlaod Conexant HDAUDIO Soft Data Fax Modem drivers from the below weblink :
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33890.exe
Download the HP Quick Launch Buttons drives from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
Download the HP Pavilion Webcam Driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33544.exe
Download the Alps Touchpad driver from the below weblink:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33751.exe
Finger Print Reader Driver :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32869.exe
Hope these helps...
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
SOURCE: Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
ara baba pleas go in bious abd change sata settings it will solve your problem
SOURCE: Hi!My laptop (HP G7000)can not
Your hard disk has indeed failed, this is not an indication of a spyware problem. Your best bet, if the laptop is under warranty, is to contact HP for a replacement hard drive.
If, however, your are out of warranty or would prefer to do it yourself, it appears your laptop has a 2.5" SATA hard drive. You don't need a huge one, your failed hard drive was probably between 80-160GB. Do not get a hard drive with a PATA/IDE interface, or a 3.5" hard drive, as these will neither work nor fit in your computer.
There are several screws on the bottom of your laptop. You will not likely need to remove the entire laptop case, and many times the bottom of the laptop is labeled with icons or a description of the component beneath the panel in question. When you replace the hard drive, pay attention to the orientation of the old hard drive, as well as where any different size screws were placed.
Finally, you will need to restore your computer with a set of disks. As you will be replacing your hard drive, any restore partition that was previously on your computer will have been lost.
Please let me know if you have any other questions related to this issue. Thanks!
