Question about Casio Music
Hi there... on of a Casio keyboard model ctk-6200 there is a jack on the back for a sustain pedal / assignable... what are the other uses for that Jack? Thank you
    Top Expert:
  • Casio Master
  • 1,530 Answers
    Top Expert:
  • Casio Master
  • 50,936 Answers
Contact Casio directly to inquire.
Posted on Feb 19, 2019
Testimonial: "Thank you for your time... I appreciate it..."
5 Suggested Answers
  • 4 Answers
SOURCE: Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Posted on Aug 15, 2009
  • 5603 Answers
SOURCE: Does the Casio LK-30 keyboard
No it does not have a sustain pedal input an there is no way to add one, sorry.
Posted on Jan 01, 2011
  • 18002 Answers
SOURCE: I replaced sustain pedal jack...now sustain is on ALL the time, even with pedal unplugged
When you replaced it, you either have the wrong jack, wired it wrong or it is shorted out where you connected it. Recheck the connections.
Posted on Dec 18, 2014
  • 3154 Answers
SOURCE: Is there a sustaining pedal Casio keyboard model ctk 401
Generally, all Casio sustain pedals are compatible with all their keyboards, but i normally recomend the SP-20. SP 20 Pedals Products CASIO
Posted on Apr 22, 2016
Apr 22, 2016 | Pedal Music
Looking for a sustaining pedal for the Casio ctk 401 keyboard. What models will be compatible?
They are all compatible. Make sure the port on the keyboard is the same size as the plug on the pedal, usually a phono plug. Also make sure it is a sustain pedal and not an "on off " switch.
Apr 22, 2016 | Casio Music
Dec 18, 2014 | Casio Wk500 Wk-500 Keyboard Workstation...
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
May 18, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Ctk-651 sustain pedal working backwards
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
Dec 31, 2013 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
Hi i have a Casio WK 1200 which has midi in and out and also one assignable jack can i use it for microphone for karaoke singing.
I think the assignable jack is for pedal assignable - Sustain, Soft, Sostenuto or Rhythm Start/Stop ONLY
No, this model does not support Mic input for karaoke singing.
Nov 04, 2013 | Casio Music
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
I just got an sp-3 sustain pedal for my casio ctk 560l keyboard but have no sound when i plug it in. How can i get it to work? I there a button i have to press or something?
Make sure you are plugging it into the place for the sustain pedal. If you happen to plug it into the audio out it may kill the sound.
Sep 29, 2010 | Casio SP3 Sustain Pedal
Is a sustain foot pedal similar to a tattoo machine pedal?
The sustain pedals have only two wires. Usually they terminate in a 1/4 inch mono plug.
yamaha USUALLY sustains when switch is closed. Roland usually sustains on a switch between the wires when the switch is open.
NO POWER should be supplied BY the sustain pedal... it is ONLY a switch.
Apr 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
41 people viewed this question
Top Casio Music Experts
Ben Armstrong
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Casio Music Expert? Answer questions, earn points and help others
