Computers & Internet Logo
A
Anonymous Posted on Feb 19, 2019
I have a Samsung monitor with buttons on the side, Model # CM23H9NS211147N. How do I turn the screen on? Thanks for your help.
Tiago Silva
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Feb 19, 2019
Tiago Silva
Contributor
Level 1:
New Friend:
Answers
9
Questions
Helped
3869
Points
14
There are Samsung monitors that turn on by simply touching on the bezel. Usually front right corner
2 Related Answers
Anonymous
  • 466 Answers
  • Posted on Oct 31, 2009
SOURCE: MY SAMSUNG SYNCMASTER MONITOR SCREEN DOES NOT COME
The cable connecting to the PC might be loose, or the part entering the monitor could be.
Try turning the monitor on, and after a few seconds, turn on the computer. You should be able to see the BIOS POST screen text flashing by. If you can't, there is something wrong in your hardware settings.
If you can, however, that's the OS resolution set too high: the monitor shuts down to protect itself. Boot in safe mode by pressing the F8 key immediately after powering up, then lower the video resolution in Control Panel display settings to something safe - 1024 x 768 usually does the trick. At that point you can reboot in normal mode and raise the resolution again to the maximum supported by the monitor (check the manual for that).
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Sep 23, 2010
SOURCE: samsung gh19ws (920nw) model lcd
Common problem is in the DC filter caps in the power supply circuits, that will be the first thing to look for first, please note that bad cap can look normal but can have high ESR.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Its not turning on. it Goes 4 colored screen then white screen when I turn pc on. please help me how to fix it as I do not know much about computers. thanks.
There is some post`s on net:similar with yours:
http://www.tomshardware.co.uk/forum/339796-33-samsung-syncmaster-s27a550h-flashing.
I have repeared some of this problems ,try this:
hold the power button and plug in ac power.and wait 5-6 sec.
try the combinations with power and menu buttons and plug the ac cord and wait 5-6 sec.
The monitor in your case is in service mode or test mode .
The other options is to change the firmweare of the monitor but you need moore tools for that.
Screen Wobbling/Shaking
Sounds like you may have a faulty high voltage supply for you monitor. I assume its a CRT monitor and not an LCD model, you do not say.
9helpful
Unlocking the keys on the screen
press the side button "Menu" 10 sec and the function "key locked" is desactivated
Samsung SyncMaster 931BF 19" Monitor. Screen was working fine. But now after raising the resolution past 1280X1024, the screen wouldn't display anything. I tried it on my older monitor, a CRT. It...
This is because your screen is not compatible with any resoultion past 1280 x 1024. Look at your screen's specifications here: http://downloadcenter.samsung.com/content/UM/200602/20060210090838125_BN59-00521A-01Eng.pdf (Page 76 listed as Maximum resolution)
If you want to go past that, you must purchase and/or use a different monitor. Just be sure to look at the Maximum Resolutions BEFORE you purchase a new monitor!
4helpful
Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
MAC screen doesnt fill Samsung Monitor
Often there is an auto correct button on the monitor, if not them press them menu button and navigate to find horizontal size. If neither of those work you might try taking apart the monitor and reseating the video cable to the monitor.
3helpful
Auto adjastment locked
Samsung implements protection into their monitors, which allows to block all settings except brightness and contrast. This "Locked" mode turns on by pressing and holding 'Menu' button for 5 seconds, and turns off by pressing and holding 'Enter' button for 5 sec.
On screen controls have a mind of their own
The buttons are stuck - If the screen is out of warranty then i would take it apart and see if he buttons can be unplugged or cleaned up.
If in warranty Samsung is excellent with repair service. - Depending on the model LCD its either 1 or 3 years warranty.
Problem LCD screen stays white bright after switch button is OFF ??
Some capacitors need to be replaced,which would have burnt out due to power fluctuations
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
