Question about American Standard Home
American standard evolution drain - the drain does nto seal and water leaks out fairly quickly, how can I fix this?
    Top Expert:
  • American Sta... Master
  • 63,993 Answers
NEW DRAIN STOPPER PERHAPS , THEY SELL THEM DAILY
Posted on Feb 20, 2019
SOURCE:
SOURCE: The pop-up drain stopper on my American Standard bathtub no longer seals in the down position. Any suggestions? KG
Unscrew it (turn left/counterclockwise), thoroughly clean it, lubricate it with liquid dish soap, screw it back in. If it still doesn't work, best bet is to get a replacement.
If, when you remove it, you find the gasket around the bottom is torn, probably ought to replace it and forego the cleaning step.
Posted on May 10, 2009
  • 9 Answers
SOURCE: hole in back of toilet (stool) leaks water.
The hole your refering to is common in the manufacturing of toilets and is generally filled before it leaves the manufacturing. I have repaired several toilets, new toilets, all American Standard, using a good grade of epoxy - not silicone. I used West System epoxy as this is made for marine projects and surprisingly states "toilet repair" as one of the uses of their product. I'd suggest carefully chipping the smooth porcelan around the hole to give the epoxy something to grip. Use a knife or screwdriver to gently chip the edges and make sure the area is dry. Press the epoxy into the hole and give it enough time to cure before putting it back in service. Of course, if the toilet is less than a month old I suggest returning it and getting a new toilet.
Posted on Jun 22, 2009
  • 297 Answers
SOURCE: American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Posted on Jul 15, 2009
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
  • 127 Answers
SOURCE: Hi Guys. My single spout kitchen faucet leaks when
spout seal kit , from what you described.
Posted on Oct 18, 2009
Drop in bathtub
people like to enjoy long, hot soak in a bathtub after a long day after work, having a proper bathtub is a must. When it comes to choosing what type of bathtub you would like, there are multiple things you need to consider.
If you have a smaller sized bathroom,
A Drop - in tub will most likely be more beneficial for space saving.
  • Drop - in bathtubs are usually lower priced .
  • You can easily have a shower head without extra plumbing hassles.
  • A drop - in tub allows you more space in your bathroom.
  • Designed with lower sides making getting in and out easier.
  • Can be fully enclosed with minimal construction.
  • Easier installation if you want a whirlpool tub.
  • Typically easier for bathing small children.
The choice of having a bathtub reflects your consciousness towards your bathroom and precise health.
And when it comes to Drop in bathtubs,
"The American Standard Evolution Bathtub"
is entirely different, universal and better fits for your bathroom.Having 21.5 inches in depth, this bathtub allows you to enjoy at least 3 inches deeper soaking bath in this bathtub. The drainage system is quick and even. American Standard Evolution Bathtub has reversible drain outlet which cleans water fast.
Read the full review to get a holistic overview including features ,specification,pros and cons.
hydro-systems-customized-bathtubs-hydrosystems-with-drop-in-bathtub-relaxation-drop-in-bathtub-nvu2yxrtj1tcjm5kl0oggpyr-5-0.jpg
May 11, 2016 | Home
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
I have an American Standard cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl is nearly gone. The flapper appears to be...
As long as the water in the bowl dosent go below the bottom rim your ok there is a trap that the water has to seal that all it needs look at the side of your toilet you will see the trap water saver
Water leaking down sprayer hose under sink. American Standard Jasmine high flow 3821.831 or 834.
They didn't put the attachment on correctly. Look at the directions for the sprayer. It's a black little piece with grey clips. U need to put it on correctly so it seals. That should stop the leak!
Jan 04, 2010 | American Standard Plumbing
I HAVE THE AMERICAN STANDARD WALK IN TUB WITH THE QUICK DRAIN AND WHEN I FILL IT UP TO USE THE JETS, THE DRAIN WILL NOT RELEASE TO LET THE WATER OUT. WHAT MIGHT BE THE PROBLEM?
It could be the pressure on the drain isn't allowing the rubber around the drain pop up to come unlodged from the floor of the tub. I have ran into this problem a few times. the best way we found to take care of it was to install a push pull type drain assembly or try and adjust the drain pop up so it pops up higher allowing the rubber around it to break the seal and start to drain. take some pictures and post them i might be able to help more
Jul 19, 2009 | American Standard 1583.470 Universal...
We have an American Standard lifetime whirlpool tub with the pop up drain (white). However, the pop up drain plug has always been tempermental but now it no longer wants to stay down.
Chances are that the drain assembly was not part of the tub but a 'generic' plumbing part. Is this pop up drain the type that you push down and it clicks closed and push down and then it pops up? It unscrews from the drain fitting and you can get a replacement at a big box store. A better pop up replacement is one called a Rapid-fit. It drains faster.
May 12, 2009 | American Standard Evolution 1599.205.020...
Replaced flaper as it was leaking in about 30 mi. Replaced and st
Hard to read you question. No sure what it is but if the flapper is still leaking it may be bcause most brand of fleappers do nto fit American Standard commodes correctly. Purchase a replacement made for American Standard only.
May 06, 2009 | American Standard Colony 2388.012.222...
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Oct 28, 2008 | American Standard 2294.011.020 Afwall...
Home Logo
69 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
