Question about Samsung Microwave Ovens
ME21H remove door switches
I have seen videos on how to remove door switches but the switch mounts on the ME21H don't seem to have a visible lock tab. How do I remove the switches?
  • Samsung Master
  • 25,835 Answers
You should not be fixing a microwave oven yourself. SUPER High voltage, a highly toxic core and numerous safety devices that need setting up precisely.
Posted on Feb 19, 2019
Dear all, I have a micro-wave whirlpool VT255/wh. My mother complains about non regular noise when she starts oven . During my tests, the oven start several times without any problem. After a while, it...
one of Fixya experts has posted a possible solution, below.
" This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Originally by
MicrowaveSvc
Hope that helps.
May 30, 2011 | Whirlpool Microwave Ovens
Clock and timer works but microwave wont heat r power on.. everything seems to work fine microwave just wont come on to cook
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Jan 10, 2010 | Kenmore Microwave Ovens
The turntable will not rotate and no heating
Thank you for posting the model number. It makes it so much easier.
This is usually caused by either a top bad door switch or a loose door switch mount, which are pretty simple problems to fix.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Oct 10, 2009 | Whirlpool MH6150XMS Microwave Oven
The letter d comes up next to the clock and now it wont heat anything up
Oct 07, 2009 | Kenmore Microwave Ovens
My kitchenaid microwave/convection oven shows "DOOR" on display
Sep 17, 2009 | KitchenAid Microwave Ovens
Microwave wont come on
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you need more help, Please reply back with your brand and model number so we can help you.
Feb 28, 2009 | Goldstar MV-1501 Microwave Oven
Microwave lights up and counts down, but does not operate
You have a failed secondary interlock (bottom door switch) or its mount is loose or broken.
Jan 11, 2009 | Sharp R-4H07 Microwave Oven
M/w only working when slight pressure applied to door button
That would be a defective secondary interlock (lower door switch) or its mount.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Jan 03, 2009 | Dacor DMT2420SS Microwave Oven
T993 - Positive Lock Switch ?
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
You can find an authorized Panasonic servicer here. You can order Panasonic parts here.
Sep 27, 2008 | Panasonic NN-T993SF Microwave Oven
Microwave runs on its own
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
solarfinder
Level 1 Expert
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
