Https://partscatalog.deere.com/jdrc/sidebyside/equipment/72146/referrer/navigation/pgId/49143
It will be opposite the normal shaft rotation.
https://partscatalog.deere.com/jdrc/side...
item 10 - yoke threaded.
SOURCE: do you have to remove the yoke to change the water
There is NO yoke. There is, however, a water pump pully attached with 4 10mm bolts which must be removed in order to access the water pump bolts (12mm). Bolts are threaded right hand (clockwise to tighten, and counter-clockwise to loosen).
SOURCE: Idler Pulley Removal
Yes, probably a 15mm socket or wrench should do. The threads lossen counter-clockwise.
SOURCE: 2005 grand cherokee. with the
it has linkage you cant see below the windshield kinda similiar to that of an old steam freight train....remember how the wheels went around?? even though the wheels went one direction at the end of that linkage the piece went in/out (back n forth)
