Question about Sharp Office Equipment & Supplies
HOW TO SOLVE ERROR 2F subcode 40 on sharp AR 5618S?
  • Sharp Expert
  • 263 Answers
Hey there. Check if the developer unit gears are okay and moving smoothly, replace the developer if it's low and key in developer command ie 25 sub 2. If it doesn't change, replace td sensor.
Posted on Feb 26, 2019
SOURCE: My Sharp Ar 5316 is showing F2 or 2F Error what will i do
My Sharp Ar 5316 is showing F2 or 2F Error what...
Posted on Nov 15, 2008
M2Tech1
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
xptareq2000
  • 1447 Answers
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Posted on Jan 20, 2010
  • 2072 Answers
SOURCE: SHARP AR M317 ERROR U2-40
That is a CRUM chip communication problem. Crums are on Drum units. Toner cartridges and Fusers.
One may have simply expierd, may have failed.
Posted on Apr 03, 2010
  • 364 Answers
SOURCE: Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Posted on Dec 19, 2014
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Jul 29, 2016 | Sharp Ar 5316
Sharp ar 5618s f2 error
check the toner or drum cart. if third party replace with OEM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 22, 2015 | Sharp Office Equipment & Supplies
Code for develpoer in sharp ar-5618s
to obtain developer code you should contact the manufacturer
Jun 04, 2015 | Sharp Office Equipment & Supplies
What is the error e7
the error e7 may have a variety of "sub-codes" attached to it, each depicting a different problem. hold the start button down to confirm the subcode. the following site offers the technical explanation of the subcodes: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=sharp&model=ar5320
that is what you asked for but i think the answer will be too technical when you look it up. but you might then google for a repair of that particular code and subcode and see what appears. for that matter, after you determine the subcode, i see no reason why to not contact the manufacturer's support and report the printer information and error code and see if they have a remedy.
here is a site for downloading a manual for such printers. it might simply be a user manual. http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0cceqfjaa&url=http%3a%2f%2fwww.sharpmea.com%2fcps%2frde%2fxbcr%2fdocuments%2fdocuments%2fom%2f34_ppc%2far5316-5320_om_gb.pdf&ei=csravj7gmuxxmaxsk4hwda&usg=afqjcnedcbf1dnyg_j2h2rxi0ll5sxjrag&bvm=bv.83829542,d.dgy
here is a fellow with a similar problem, an e7 error. but you can see that he was trying to clean the laser and probably disconnected something. http://www.copytechnet.com/forums/sharp/41980-sharp-ar5320-error-code-e7.html?s=84de82058651b6d355c5f09853183f36
good luck.
Jan 21, 2015 | Sharp AR-5320 Black and White Copier
Dec 19, 2014 | Sharp Office Equipment & Supplies
Sharp ar 5620 photocopy error f2
F2 errors means problem with toner supply or toner cartridge itself. For better understanding it is necessary to obtain a subcode by pressing START key. Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
Apr 15, 2013 | Sharp AR-M237 Copier
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
http://www.manualslib.com/manual/902246/Sharp-Ar-5618.html?page=55#manual
Jul 06, 2012 | Sharp Office Equipment & Supplies
A brand new sharp AR5516, on the first day of installation its giving me an error code 2f 40
mnedd to install properly all the program we need ,because the f2-40 is wrong country ,wrong cartridge .crum data read problem
Sep 04, 2011 | Sharp AR-5316 Advanced Digital Imager...
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
