On the Sky Remote: 1. Press TV2. Hold Select and Red until the LED Blinks twice3. Enter 0206 (The Led should Blink twice)4. Press Power. Worked on mine
Try keeping the handset menu button pressed for abount a minute, then check the other buttons again, this sometimes works - the set software seems to 'lock-up' causing this problem.
John
To reset your bush internet t.v. remote after replacing the batteries you must press left down right and number 1 at the same time. You must do this whilst pointing the remote at the t.v. set.
Hi John
If you havent allready try unpluging the unit from the mains.
Leave out for 5 mins then plug back out & allow system to reboot.
Cant guarantee this will work but it does solve a lot of digi box problems.
The Konig IR9982 is not a universal remote control so there is no code to make it work your Bush TV. It is actually a direct replacement (electronic clone) remote for some Hitachi models.
You will need a direct replacement for your particular model, try http://www.remotesreplaced.co.uk/television/remote-control-bush.htm
