Question about The Computers & Internet
I have a 64 g c330 lenvono chromebook and I got an update msg for 32 bit the first update and now its upa=date time again and its giving me the same update info...Is something not right
    Habit-Forming:
    New Friend:
  • 93 Answers
Sometimes it just wants to put the 32 first even though its not what your system is, really? yup. then it will put 64. *shrugs* mine does that also.:)
Posted on Feb 22, 2019
  • 70 Answers
SOURCE: 32 bit program to 64 bit opperating system
From the Autocad webiste:
System Requirements AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements Recommended configuration (excluding server components used with project management capabilities):
  • Intel® Pentium® 4 (3 GHz or higher); AMD Athlon™; multiple processors supported, dual-core supported
  • 32-bit only: Microsoft® Windows Vista® Ultimate/Business/Enterprise, Microsoft® Windows XP (SP2)
Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Here's how you should be able to run it in compatibility mode:
1. Right click on the Autocad Icon in your start menu
2. click on Properties
3. click on the Compatibility tab at the top
4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
Posted on Feb 07, 2009
  • 3940 Answers
SOURCE: IE 32-bit browser need to run on my 64-bit browser
The Internet Explorer shortcut in the Quick Launch toolbar and in the Start menu of Vista x64 will run the 32-bit version of Internet Explorer by default. Why run the 32-bit version if IE on the 64-bit version of Vista?
There are actually two shortcuts for Internet Explorer in the "All Programs" menu. Why two and what's the difference?
Here's the title of each and the exe's they run:
Internet Explorer
"C:\Program Files (x86)\Internet Explorer\iexplore.exe"
Internet Explorer (64-bit)
"C:\Program Files\Internet Explorer\iexplore.exe"
The first one runs IE from the "Program Files (x86)" folder, this is the 32-bit version. The second one is the 64-bit version.
Reference:
http://pietschsoft.com/post/2006/12/03/Vista-Experience-Update-Windows-Vista-x64-runs-32-bit-Internet-Explorer-by-Default.aspx
Posted on May 01, 2009
  • 11 Answers
SOURCE: 32 bit IE won't connect to internet in Vista 64 bit.
32 bit programs, last I checked, won't work in a 64 bit operating system, just as 64 bit won't work in 32 bit operating systems.
If 32 bit programs will work in a 64 bit OS, they probably won't work properly.
Posted on Jun 08, 2009
RescueTechLA
  • 2653 Answers
SOURCE: belkin f5u109 64 bit device driver for usb to
There aren't any 64 bit drivers for it available, at least publicly. You can email their support and request them.
Hopefully they'll hook you up.
Best of luck!
--RescueTechLA
Posted on Nov 28, 2009
  • 6 Answers
SOURCE: Garmin c330 update
I'll never buy another piece of **** Garmin. You have to pay out the *** for the thing and then they charge you out the *** for maps to use it. Tom Tom maps are free.
Posted on Jan 15, 2010
Cant up date m/s security essentials or delete
Step1 Ensure that the date and time are set correctly on your PC
Open Microsoft Security Essentials.
If the error message that you received contains the code 0x80072f8f, the problem is most likely caused by an incorrect date or time setting on your PC.
To reset your PC's date or time setting, follow the steps in Fix broken desktop shortcuts and common system maintenance tasks.
Step 2
There are other things that you can do however the most easy way is to install updates manually
Manually install the virus and spyware definition updates
If you're running a 32-bit Windows operating system, download the latest updates manually at http://go.microsoft.com/fwlink/?LinkID=87342
If you're running a 64-bit Windows operating system, download the latest updates manually at
http://go.microsoft.com/fwlink/LinkID=87341.
Click Run. The latest updates are manually installed on your PC. http://go.microsoft.com/fwlink/?LinkID=87342 http://go.microsoft.com/fwlink/LinkID=87341
Apr 08, 2016 | Microsoft Windows 7 Ultimate. Windows 7...
Tip
Windows 7 Updates Running TOO SLOW, or just plain "hanging up / freezing"??
Anyone out there in "Windows7ville" experiencing those DREADED slooooowww updates, or is it seeming to hang / freeze without actually downloading and installing your security updates??
I struggled with this exact same issue regarding Windows 7 Updates.. (SLOOOW download times, Win7 Update basically "hanging" at the "searching for updates" portion of the install procedure), you name it! Fortunately, I got fed-UP with these problems and "dug down deep" in researching for a "fool-proof" solution!
This issue apparently stems from the fact that Microsoft in all their "wisdom" decided to change how their update servers "hand out" their updates to computers requesting Windows 7-related updates, after Windows 8/8.1 was released.
Here's the fix(es) which worked for me:
First, we need to find out what version of Windows 7 (32 or 64 bit) we have:
Click the Start button. Right-click "Computer", and then left-click "Properties" from the resulting pop-up menu. This will bring up a new window showing what version of Windows 7 you have, what type of CPU, how much system RAM, and most importantly if it is 32 or 64-bit.
(For this solution, I'm assuming that one has the 64 bit version of Windows 7. If you have 32 bit, then at any time during this process you see a different choice to download the 32 bit version of an update, please do so. Also, you MUST have Service Pack 1 installed on Windows 7 for this guide to be successful. If you don't have it installed yet, please download the full installer and run it before continuing: https://www.microsoft.com/en-us/download/details.aspx?id=5842
Make SURE you restart once SP1 has finished installing!)
First, click the "start button" (Lower-left corner of your screen.. looks like the windows logo in a "bubble"). In the search blank at the bottom of the "start menu", type in "cmd". When it shows the result, right-click it, and then left-click "Run as Administrator". Keep this window open, but shrunk-down and off to the side a bit, as you'll need to run a command a couple times during this process.
1.) Type in (or copy and paste this) into the command prompt:
net stop wuauserv
Press "enter" / "return". This will completely stop the background Windows Update service, preventing it from interrupting our repairs / updates to Windows Update.
2.) Download and run (I recommend Google Chrome or FireFox browser -- steer clear of using Internet Explorer, as it's FULL of non-fixable security flaws!!):
https://support.microsoft.com/kb/3138612
This will ask you if you're sure you'd like to run this. Just keep saying "yes" or "ok".. (basically give it a positive response until it finishes). When it's done, restart your PC.
3.) Once your PC has fully restarted and you're back at your desktop screen, (you can see your wallpaper and all your "usual" desktop icons), REPEAT STEP 1... Then go back onto the web. Download and run:
https://support.microsoft.com/en-us/kb/3102810
Once again, give it "positive responses" if it asks if you're sure you want to install this update package... Restart your PC once more after it's done.
Now, If you'd like to get all the most needed and necessary security updates done and over-with in "one fell swoop", then download and install the "Windows 7 Convenience Update", which will get your PC up-to-speed and up-to-date with security fixes MUCH more quickly!!
(Again, please repeat Step 1 before continuing!)
First, we'll need to run a quick "service stack update" on the updater service. Download and Run:
https://support.microsoft.com/en-us/kb/3020369
On the service stack update page, remember to pick from the first two choices, based on if you have 64 bit or 32 bit.
Restart your PC once it's finished!
Repeat Step 1.
Now, onto the "Convenience Update"
Download and Run:
For 64 Bit:
http://download.windowsupdate.com/d/msdownload/update/software/updt/2016/05/windows6.1-kb3125574-v4-x64_2dafb1d203c8964239af3048b5dd4b1264cd93b9.msu
For 32 Bit:
http://download.windowsupdate.com/d/msdownload/update/software/updt/2016/05/windows6.1-kb3125574-v4-x86_ba1ff5537312561795cc04db0b02fbb0a74b2cbd.msu
As "always", restart your PC once the update finishes!
I hope this helped someone! Please let me know if it did, and have a truly excellent day!
on Apr 21, 2017 | Microsoft Windows 7 Professional 64 Bit 3...
Cant update m/s security essential
Step 2
Apr 08, 2016 | Microsoft Windows XP Home Edition
Download for a x64-based PC . every time i try to update it tells me i need either a (x86)bit or (64)bit . my system is 64
The computer hardware may be 64 bit but is the Operating system you have loaded 64 Bit or 32 BIT?. If you have a 32 Bit operating system loaded this would explain your problem.
Feb 25, 2015 | Toshiba Satellite Computers & Internet
Am I running 32 bit or 64 bit version of Office 2013?
Open Word, go to the "File" tab, and click "Help".
Jul 21, 2014 | Microsoft Computers & Internet
Free download windows xp
The program was written in 1995. It was developed with max capability of 32 bit. The system fails at 64 bit. I wrote the update which made it compatible with XP, Vista and Win 7... 32 bit. I am considering trying to update the program to 64 bit but I'm not sure if the effort will be worth the time to achieve a working copy. In the long run it may shrink to its core functions which are the nice checkbook features. If you have an old 32 bit system around that will keep this great program functioning for a while.
Bill
Jan 06, 2014 | Computer Associates Kiplinger's CA-Simply...
I have a DELL Inspiron 1720 with windos vista. I am trying to install windows 7 but it is showing me this message: OEM Name : DELL INC OEM model: Inspiron 1720 BIOS version: Phoenis ROM BIOS plus...
You need to check the specifications of your laptop it may not be able to run Windows 7.
You need these specs:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Sep 17, 2011 | Dell Inspiron 1720 PC Notebook
Instant dvd recorder software 'not responding'
Hello Joshua,
Instant DVD Recorder 2.6.1 UPDATER
  • Please install the Instant DVD Recorder 2.6.1 UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video Creator or Dazzle Video Creator Platinum with a previous version of Instant DVD Recorder. This updater also includes the hardware drivers.
  • If you are using a Dazzle product already that includes Instant DVD Recorder version 2.6.1, then you do not need to install this update.
New with this version:
  • added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
  • Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
  • 16x9 detection
  • PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
  • Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • and other compatible hardware
Installation Instruction:
  • To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
  • To install this Instant DVD Recorder version not as an update but as a full version you need to enter your Instant DVD Recorder Version 2.x serial number during the installation process. The serial number was included in your Dazzle product.
  • With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
  • If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
  • If you use this Instant DVD Recorder Updater to update the Instant DVD Recorder included with Studio Version 12, 11 or 10, please make sure that Instant DVD Recorder is already installed on you system. Please note that the version of Instant DVD Recorder included with Studio Version 12, 11 or 10 can't be installed under Windows Vista 64.
For Windows XP
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Windows Vista 32 Bit
For Windows Vista 64 Bit
For Windows 7
Sep 15, 2011 | Pinnacle Dazzle DVD Recorder
Video does not open. gives me a update flash message. done iot many times
you might be using a 64 bit operating system and you're trying to play videos from websites like youtube or facebook which would require you having flash player installed in your computer. flash player is currently not compatible with 64 bit browsers. the solution: use internet explorer 32 bit. or download google chrome or firefox and try accessing and playing online videos from there.
Sep 07, 2010 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
Top The Computers & Internet Experts
Inky Fingers
Inky Fingers
Fred Sops
Jorge Smith
Jorge Smith
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
