Question about LG Cell Phones
Lg d727 - ive factory reset it i have tried putting it in download mode i have done everything possible i could think of it is stuck on the start up screen that says 640 error certification verify
  • LG Master
  • 1,527 Answers
Posted on Feb 20, 2019
SOURCE: how to reset factory settings of samsung sync master710v
Disconnect de power Cord behind the monitor for about 10 minutes. Then reconnect again. If the problem persist you can call the Samsung and talk about your problem. I had the same problem they swap my monitor, because was a fault (if your monitor still in the warranty.
Posted on Aug 17, 2007
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
Posted on Sep 14, 2008
Basti
  • 1447 Answers
SOURCE: Printer stuck in copy mode--can I reset the printer? Have tried everything.
Hi
Try to turn it off and unplug it for a few minutes, turn it back on and leave it to copy mode. try printing from the computer then/ keep us posted.
Thanks
Posted on Nov 14, 2008
SOURCE: stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Posted on Mar 17, 2009
  • 846 Answers
SOURCE: Touch Screen is unresponsive.
If Verizon doesn't replace it for you, you can find the touch panel at Droid Repair and there is a guide that shows you how to put in the part at Droid Repair Guide.
Posted on Apr 26, 2010
Get my lg destiny in safe mode
Try removing battery , then restart phone
Sep 29, 2016 | LG Computers & Internet
My lg model 50pa4500 lost a channel tried everything to get it back an no luck need help
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 26, 2016 | LG Televison & Video
Menu 0000 is not working and I need to factory reset tv
Aug 24, 2016 | Televison & Video
How do you hard boot into recovery mode,volume down and power then release both and press again on lg screan dont do it both ways only factory reset
Do not forget to backup your phone’s data before doing a factory data reset. Here’s our guide.
Performing a Factory data reset restores your device to the original factory settings as it comes out of the box. It also deletes the data like installed apps, contacts, messages, images, etc. present on the internal storage. It does not, however, affect any data stored on the external SD card. Now here is how you can hard reset your LG G2/G3 from device Settings:
Tap the Menu key from Homescreen.
Select System settings> General.
Now scroll to PERSONAL.
Select Backup & reset option.
Tap Factory data reset> Reset phone.
Select Erase everything.
When the warning window prompts, tap OK.
Hard Reset LG G2 with Hardware Keys
If you unable to perform a factory data reset on your LG G2/G3 using the device settings for some reasons, you can try the hardware key method. Just follow the steps given below:
Turn off your LG G2/G3.
Now press and hold the Power + Volume down buttons simultaneously for about 8 seconds.
When the LG Logo appears, release and then immediately re-hold the Power button.
Release the Power key as soon as you see the ‘FACTORY HARD RESET’ screen.
Press the Power key to reset your device.
Press the Power key again to confirm factory data reset.
Wait till reset is done.
Boot LG G3 /G2 into Safe Mode
To fix an issue caused by a 3rd-party app, you can boot your LG G3/G2 into Safe mode and delete the suspect app. You can turn on Safe mode by following these steps:
Jan 06, 2016 | LG Cell Phones
Ive got an LG Optimus D415...Android kitkat 4.4.2 and until a few days ago...great phone. I have now acquired a defective back arrow or back button key. It is annoying as hell....and ive done two master...
Still, so many things can be wrong. Like a slight corroded connector or flat cable a defect integrated circuit or one that is rapidly becoming defect. I think a technician should have it on his workbench to find out what is the real problem, but that will cost.
If you did everything on the software side, like resetting, reinstalling and so on, and the error keeps coming back it must be something in the hardware. Not even wishfull thinking can change that.
Nov 01, 2014 | Cell Phones
My lg tv is stuck in standby
Do a reset to this set, and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so.This procedure will make it a hard reset.If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.If you wish to get some details; check the site linked here.Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given.Never forget to exit the service mode, after all adjustments have been done.
Sep 30, 2014 | Televison & Video
My lg optimus s is stuck on safe mode how do I get it back to normal
Factory reset should be the last thing you try. Dont take this the wrong way, (I just dont know what you have done, why you are in safe mode, etc), but have you tried just re booting it, ie shutting it off and turning it back on normally? If that doesnt do it, pull the battery out, wait about five minutes, then put it back in and turn it on again.
Mar 09, 2011 | Cell Phones
Galaxy p1000 is frozen cant switch off nothing is happening
Hope this helps:
How to Hard Reset Samsung GT-P1000 Galaxy TAB:
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
Hard Reset Samsung GT-P1000 Galaxy TAB with keys With the Samsung Galaxy TAB turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Feb 05, 2011 | Samsung Galaxy Tab Tablet PC
Cell Phones Logo
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
