Question is about the HP printer.
Connecting to Hp printer in your device is very easy. If you have installed the window 7i your device and want to connect hp printer in your system so at first connect to hp printer with your device, at this time a message shown on your screen, right click on it and install the setup. Still, you are facing the error on your device so don't be frustrated call on hp printer support 1-888-315-9712 and get a quick solution. http://printer-help-number.com/hp-printer-support.html
SOURCE: HP Compaq nx7010 Notebook PC Windows7 Driver?
Windows 7 is not yet officially released(only the beta(testing) version is out)
Hence forth there are not drivers available for windows 7. Click on the link below to see all the available drivers for your laptop.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=380681&lang=en&cc=us&prodTypeId=321957&prodSeriesId=380679&taskId=135
SOURCE: Just installed HP p6240f desktop with Windows7.
First, I thought your assistance center would respond to my request since this same problem appears in the HOP website problems & solutions.
I did not resolve the problem after downloading the All In One Series software. It failed to complete the installation after hours of loading.
I did my own tasking and found that I could resolve my oproblem by Control Panel - Devices (printers) - HP 7130 Officejet-Scan Document.
It worked.
Savuing the scanned document is quite different in this Windows7 setup from the prior XP. It is more circuitous to get to where I want to place the file.
SOURCE: Windows7 is not compatible with my Cannon Pixma MP170 Printer
There's still hope for your printer. Just download the MP170 update driver support for Windows 7 from your printer manufacturer.
I've already taken the liberty to search the driver for you. Click here. Just put in Windows 7 on "Select OS".
Hope this helps. Thank you for using Fixya.
SOURCE: i have a loptop with windows7 so i can install HP
There are a few variants of the P2015 - see here
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=1845551
if you click on your exact model - you will then be taken to a menu to choose the windows version - I checked on the P2015 and there is a windows 7 driver available
Download the drivers and then double click on the exe file to install.
SOURCE: I need windows7 drivers for my HP Pavilion dv6830
www.driverssolve.com/sw/83842.html
www.latestdriversupdate.com/driver/58248.html
you can download the drivers from the above links.....
