TV will not power on after power surge was accidentally turned off. I change remote battery too. I disconnect cable from TV. Pls help
You can get other ICD for it, cheacp and legal CD Keys, Games Gold and Games Items are available on https://www.m8x.com, if you need some, you can have a view there, good luck to you
SOURCE: hi, need help on remote.
Easiest way to go about this is to go to your local store and look on the back of the universal remote packages. The manufactuer will list all of the brands that their remote is designed to work with. Find Acer, and your problem is solved. Another option is to call Acer and see if you can order a new remote. The customer service number should be on their website.
SOURCE: my panasonic 32 lcd tv tc-32lx60 will not turn off
Really sorry abou that. Here's the transcript.
http://www.fixya.com/support/c36637
I have been posting responses all the way through. But you were not able to see them, possibly due to some kind of bug
SOURCE: philips TV won't turn on
There is no quick Fixya to this problem, As a repair tech I understand but your PSU power supply unit overheated causing you logic board to give you this flashing red light, I cannot help you 1,500 miles away and would like a good rating for the information though, phillips has so many autherized repair centers that I would call if I where you, this can be fixed for under $100 bucks phillips manavox psu boards are cheap and the labor will dpend on where you live, if this information find helpful to you please rate accordenly thank you and good luck!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: keep getting disconnected from xbox live, for 5
Is your X-box wireless and are you using a wireless router?
If you are using a wireless router and it is getting disconnected, then you will need to check the wireless settings of the router.
You can try to upgrade the Firmware of the router. or change the advanced wireless settings of the router.
On your wireless router you will find the advanced wireless settings.
You will need to change BEACON Interval to 75.
RTS threshold to 2307.
Fragmentation threshold to 2306.
if possible then reduce the MTU on the router to 1365.
For more info about networking Click Here
SOURCE: my samsung 330 lcd-tv wont turn on. the red power
Hi my name is Roety,
I can help you with your issue ,
Most common issue is the power supply capacitors, check and replace any that look swollen like this
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
