Question about LG Refrigerators
The clip on the inside of my LG French door fridge is not working properly. It looks like it has moved down. how do I fix it?
    Top Expert:
  • LG Master
  • 60,416 Answers
NO CLUE AS CAN NOT SEE WHAT YOU HAVE PROBLEM WITH .
Posted on Feb 21, 2019
cresguy
  • 75 Answers
SOURCE: outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Posted on Jul 25, 2008
rickzilla
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
SOURCE: Thermador Freedom T361T70NNP - French Doors - Condensation
I have the same problem, and thermador stated there was a recall on the hinges. They are replacing the hinges to a newer stronger hinge that will pull the refrigerator doors in tighter. It took three different service companies to find the answer to this problem because I was told Thermador does not want anyone to know about this issue they have.
Posted on Aug 19, 2009
projdoc
  • 2237 Answers
SOURCE: Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Posted on Aug 26, 2009
woodchuck789
  • 4070 Answers
SOURCE: water dispenser is not working
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Posted on Oct 05, 2009
Everything in and outside our fridge is getting a black soot on it?
This sounds dangerous, I suggest you hire a pro to look into this.
Nov 21, 2017 | LG LFX25971ST Bottom Freezer French Door...
I have a LG refrigerator LFX25980n with FF failure, how to fix?
Is the freezer cold, but the refrigerator part is not cold?
If so, "FF" probably means fan failure. The fan which moves cold air from the freezer to the refrigerator is not working properly. The fix is to replace this fan.
Oct 09, 2009 | LG 24.7 cu ft Panorama French Door...
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Jul 03, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Ice Cube Maker
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
LG Fridge...door strickers
here is a link to an exploded view of your fridge model.. which parts are you looking for? Perhaps your description of the part differs from mine.. what is the part you need? Please be specific so I can assist you in finding a supplier...
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Exploded.pdf
Aug 10, 2008 | LG LFX25960ST Stainless Steel French Door...
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
I moved, and now the water no longer comes out the door
The electrical connector at the top of the hinge cover is not connected properly.  Pull the left hinge cover and make sure that the electrical connections are secure.
Jun 19, 2007 | LG LRFD21855 Stainless Steel French Door...
Refrigerators Logo
29 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
