SOURCE: 2001 Blazer door hinge pins and bushing replacement
you need a special spring compressing tool to remove and reinstall the hinge spring and then its a matter of removing the door installing the new bushing and rehang the door with new pins ive tried doing this while leaving the door on the car trust me its just harder that way good luck and please rate -jeff
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
SOURCE: frost free freezer with ice in the bottom and
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
SOURCE: water dispenser line leaking at bottom of freezer
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
SOURCE: Refrigerator door fell off.
Fridge fell off in my hand. I understand the idea of how it works on a lower and higher metal pivot. The pivot closest to floor seems to be missing a washer, screw or nut. I need an illus of what may be a missing part. Then an idea of how the door is lifted onto said pivot- With Ease!!
