SOURCE: Waveguide cover
If it's damaged and cleaning won't take care of it, you can buy a new waveguide cover from Tritronics at http://www.wehaveparts.com
We have the full service manual at our site for your convenience:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Waveguide cover for Kenmore microwave
Try replacing the screws with larger ones. Maybe you ordered the wrong piece, if your microwave comes with a mica cover (A fine, square piece of mica) and you received a plastic one, you will need to get the right piece or adapt the one you received.
You can get the mica cover on any microwave service.
SOURCE: need a new sharp waveguide cover
The best place to order Sharp parts is Tritronics.
Have your model number handy.
SOURCE: Sharp R403 microwave internal electrical short/fire
This is a simple problem & solution.
Quite
often this is due to grease or food particles stuck somewhere in the
cavity of the oven or stuck on or behind the waveguide cover.
The
waveguide cover (also called a spatter shield) is usually about the
size of a playing card and often held in place by a plastic rivet.
It can be fragile, and
the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal
behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of
the oven is chipped or charred, it will have to be sanded smooth and
clean and dried thoroughly.
Then you can apply some
high-temperature appliance paint, available from places like Wal-Mart,
Lowe's or Builder's Square.
Since your waveguide cover
is damaged, it will need to be replaced. It provides important
protection for the magnetron.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
We're
