SOURCE: A display problemin P910i
MAn I m having d same problem....
how u make the screen work
please tell me
mail me at
[email protected]
9463126256
SOURCE: What is the difference between
I think the matching remote totally matches down to the LED display of light level. Coordinating remote does not have the LEDs.
Is this a new installation? New installation then wiring might be bad.
Or older installation that has stopped working? Timer might be bad.
The Leviton 6124 is rated for incandescent light bulbs up to 1200 watts, and does not appear to be rated for CFL, but could possibly work with CFL and LED.
Change bulb to incandescent.
Copy following link to identify timer, and correct wiring.
http://waterheatertimer.org/pdf/6124-manual.pdf
http://waterheatertimer.org/Programmable.html#wire
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
https://www.leviton.com/sites/REST/controller/LCDownloadController/download/DI-000-VPT24-02F-W.pdf?docurl=/en/docs/DI-000-VPT24-02F-W.pdf
Yes, but appears to be non-serviceable... and its probably just a 3.2vdc lithium coin battery inside the case yet they decided to make it so you have to buy a replacement every 10+yrs. Crack it open and see (dill off any rivet heads).
