Question about Sony BRAVIA Televison & Video
Where can I get screws of a table stand bravia model:kdl-40v4100, please.
    Sergeant:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 122 Answers
Although I am just guessing, most Sony equipment uses metric screws. Go to a Home Depot or similar store and take the piece that you have that contains the threaded fittings and they will help you find the screws you need. https://www.manualslib.com/manual/793567/Sony-Kdl-32xbr6.html?page=7#manual This page of the manual gives some info about the screws such as not longer than 1/2" (or 12mm) to prevent damage to the set. Sony customer service may be able to supply replacement screws too.
Posted on Feb 18, 2019
SOURCE: KDL-46V2500 Please show back panel. which screws are mounting screws
yes, i removed mine. no problem.
Posted on Nov 05, 2008
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
  • 148 Answers
SOURCE: My Sony Bravia KDL-40V4100 JUMPS TO STANDBY MODE
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ....If this helped you (or not) then please rate, thank you!3c91ad5.jpg
Posted on Feb 03, 2010
  • 102 Answers
SOURCE: i need a table top tv stand for my sony kdl
hi here is a link to the stand for your tv at sony parts store >
http://www.partstore.com/Part/Sony/Sony/KDL40W3000/Sony/Sony/A1257997A/New.aspx
please dont forget to rate me i need a few more for my badge thank you and if you need anymore help let me know..
Posted on Feb 04, 2010
SD Tech
  • 14553 Answers
SOURCE: screw size for attaching stand for Sony Bravia LCD TV model# 46W4500
while the owner manual does not specify the length etc of bolts it does show there are 4 of them---look like find thread machine bolt---may be able to buy a few at the hardware sore or Home Depot---if the threads are inside the base take it with you as a guide.
http://download.sony-asia.com/consumer/IM/4106869131.pdf
pretty stupid as owner manual has everything including dimensions and weight etc but no list of bolts size.
Posted on May 20, 2012
Looking at a negative screen
Sony Bravia KDL-40V4100 models have a problem with the screen going blank, faded or washed out ( negative ghosting) . It is caused by a bad chip on the T-con board. A replacement chip is available from shopjimmy.com (Sony 55.40T02.C08 T-Con Board Component Repair Kit) for $14.95- If your not an excellent solderer, send your board to them for a repair $69.95.
Feb 11, 2014 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Tip
Sony Bravia KDL-40V4100 LCD TV user manual
Looking for free copy of owners/ user manual for Sony Bravia KDL-40V4100, click that link to download PDF file of required owners/ user manual.
PDF file can be seen on computer by adobe reader software that is freeware and can be downloaded from adobe.com for free.
Please make sure that your computer has adobe reader installed before to download user manual copy. Once user manual appears in browser window, you can save it in your computer to consult it any time or get its print out through printer.
User manual has all operational details about product and will help you to understand all functions, button location on unit, its function details.
Lamp replacement procedure is also written in user manual.
Owner manual gives you info about hooking it to other gears like DVD Recorder, and Computer etc. User manual also suggest some steps of user level troubleshooting before sending it in service center.
You will see many features of unit described in user manual with details with supporting images for easy understanding, menu content list with icons is also helpful for user.
Hope this tip will helps you so hit Yes button as it wont cost you anything :)
on Sep 21, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
KDL-40V4100 service menu
well known information but do you have some problem?
Apr 01, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
How do i remove the table top stand from my sony bravio model KDL-52V4100
Need replacement screws for my sony 52v4100..I lost the screws for the table top
Jan 28, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
May 08, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
I need the screw size for 4 scews to re-attach a Sony Bravio 40" LCD to the stand
I assume that its Sony KDL-40S2000 model and it needs following size screws to attache its table stand..
PART NUMBER.. 258060201.. SCREW, +PSW M4X12
Available in Part Store.
Hope that info will help you.
Thanks.
Nov 15, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Clicking sounds when turning off Sony bravia kld-40v4100
ACTUALLY WITHOUT SEEING YOUR PROBLEM PHYSICALLY I CANN'T SAY ANY THINK, BUT FOR YOUR KNOWLEDGE LET ME TELL YOU NO TV MAKES ANY KIND OF SOUND DURING SHUT OFF. & you are saying for more than 30sec, i think you should call the SONY TECHNICIAN for visit.
Dec 20, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Open Questions:
Televison & Video Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
